Page 1 of 5
Re: The LandYacht BMW E39 Saloon
Posted: Tue Apr 21, 2020 8:44 pm
by Bratitude
Jack Bauer wrote: Tue Apr 21, 2020 7:10 pm Out with the old drivetrain , adapter plate ready to mate the Siemens motor to the new 530d gearbox and snagged a deal on a new battery for the Yacht :
https://www.ebay.co.uk/itm/2017-BMW-740 ... 4244520233
Battery looks like to be those lg Chem modules?
Very nice.
Posted: Fri Apr 24, 2020 1:46 pm
Just arrived:)
Posted: Fri Apr 24, 2020 1:47 pm
Siemens motor and 530d gearbox installed.
Posted: Fri Apr 24, 2020 2:24 pm
by Dilbert
Jack Bauer wrote: Fri Apr 24, 2020 1:46 pm Just arrived:)
How much was the shipping on that?
Is it much bigger than the normal 5 series petrol tank?
Posted: Fri Apr 24, 2020 2:44 pm
total inc shipping 950 euros. It would fit the E39 fuel tank space but I would need to do some serious metalwork to make mountings. For now it's just going in the boot:) Once the car is driving I might pick up another and do the fuel tank thing in Dave's workshop on the lift.
Posted: Fri Apr 24, 2020 4:18 pm
by Dilbert
Jack Bauer wrote: Fri Apr 24, 2020 2:44 pm total inc shipping 950 euros. It would fit the E39 fuel tank space but I would need to do some serious metalwork to make mountings. For now it's just going in the boot:) Once the car is driving I might pick up another and do the fuel tank thing in Dave's workshop on the lift.
That's fab, great to see the supply of parts making their way onto the second hand market.
Posted: Sat Apr 25, 2020 1:52 pm
First look inside the new battery.
Posted: Sat Apr 25, 2020 5:53 pm
Give it some 12V power and capture that canbus Damien. :D
Then I can compare it to the I3 and see if any changes are needed.
Posted: Sun Apr 26, 2020 10:31 am
I'm on it:)
Posted: Mon Apr 27, 2020 11:58 am
Got a chance to dig into the battery today. Connected up 12v, ground and can to the external connector as well as bypassing the hvil pins. On startup draws about 260mA for 10 seconds then drops to zero. I guess its expecting a terminal 15 over CAN to wake up. Tried some of my captures but no response. Given the age gap between my cars and the G11 it must be like trying to hack the pentagon with a Commodore 64. No can transmission on the external bus. Stripped back the loom tape on the cables going to the bms controller. The blue plug has ten wires :
2x brown with black strip grounds
2x red with white strip 5v supply to slaves (NOT 12V!)
2x blue fault lines
2x yellow with red strip CAN High
2x yellow with brown strip CAN Low
CAN runs at 500kbps.
Attached two captures. One while supply 12v via the external connector to the bms controller and the other while supplying 5v into the red/white wires on the bms internal connector.
Do your stuff Tom:)
Posted: Mon Apr 27, 2020 12:59 pm
Looks really close, however no real clue how the package the remaining 4 voltages.
But if you have a teensy 3.2 with can transceiver or a SimpBMs on hand give the BMW I3 code a go.
Posted: Wed Apr 29, 2020 8:41 am
No luck with the i3 code so far.
Posted: Wed Apr 29, 2020 9:57 am
How are you testing it?
The bmw modules need to be powered down, when the get powered on they go through a sequence requested by the BMS master to do checks before reporting anything.
So start up sequence needs to be, power on (5V) can bus from the master.
However might be the stupid checksums vary from I3 to PHEV which would be a pain as that was the most work to figure out.
Posted: Sun May 03, 2020 2:52 pm
Making progress on the E39. Modified the mounting frame to take the Prius inverter. Trial fitting looks good so far.
Posted: Sun May 03, 2020 5:12 pm
Posted: Sun May 03, 2020 7:45 pm
by mike77cos
I know what I'm doing when I've got the baby to sleep
Posted: Sat May 09, 2020 6:00 pm
If you just get a micro to send the modules the messages 0x80, 0x81, 0x82, 0x83, 0x84, 0x85
The way as they are in the attached document. Find it weird the PHEV has different canbus message structure then an I3 or I8.
Posted: Sun May 10, 2020 3:25 pm
by sprocketman
If you connect to the main connector on the battery pack you should be able to comunicate by can to the HV realys and the BMS system. ( if you can work out what can messages to use)?
The 740e may be differant but on the 330e they are:-
Connector A332*1B
1 Supply terminal 30 red
2 High voltage interlock loop signal Green
3 Terminal 30C signal red
4 not used
5 not used
6 wake up signal terminal 15 yellow
7 not used
8 not used
9 not used
10 Supply refrigerant shut off valve Blue/ purple
11 activation refrigerant shut off valve Blue/ black
12 ground black
13 PT CAN2 bus Brown
14 PT CAN2 bus Yellow
15 PT CAN2 bus Brown
16 PT CAN2 bus Yellow
17 not used
18 not used
19 not used
20 not used
21 not used
22 not used
23 High voltage inter lock loop Green/red
Regards
Andrew
Posted: Wed May 20, 2020 5:17 pm
This will have to be a photo update. Too tired to type
Posted: Fri May 29, 2020 4:28 pm
Posted: Mon Jun 01, 2020 3:33 pm
Siemens motor now spinning in the E39 using the Prius Gen 3 MG2 power stage.
So of course I selected 5th gear, pulled on the brakes and wound on the power. MG2 shuts down at 500amps peak. That's around 350amps rms. Even in 5th with a 530d drivetrain, brakes on and the wheels chocked she was creeping forward.
Posted: Mon Jun 01, 2020 4:08 pm
by mdrobnak
Nice!
How do you end up figuring out the max safe Amps to set for the long term? Watching temperatures? 500 Amps is fun, but only if you can do it more than once. ;)
-Matt
Posted: Mon Jun 01, 2020 5:30 pm
by Isaac96
140kw of pure torque... Nice!
I'm almost ready to run my Siemens motor, could you share your parameters when it's convenient for you? I have no experience with tuning induction motors and I'd like to have a baseline :)
Thanks!
-Isaac
Posted: Tue Jun 02, 2020 3:09 pm
Params attached. Very early stage of tuning.
In other news got the Tesla charger and V5 logic board running today. Seems to be a few bugs in the code still but with an actual charger running in a car will make it easier to hunt down.
Posted: Tue Jun 02, 2020 5:46 pm
by Isaac96
Thank you Damien! Much appreciated :)
-Isaac
