Classic Mini (newbie)
PEDR0
Has thanked: 9 times
Been thanked: 7 times
Post by PEDR0 »
Hello all, Having just had a couple of heart attacks i have found myself with a lot of time on my hands, The upshot of this is i came across Damien on youtube, don’t worry Damien, I have NOT liked or Subscribed.
This has caused we to rethink my abarth mini project and go electric!!
Due to the british leyland/morris garages collaberations of years gone by i would like to go down the MG route
I will be starting with a bare shell which was allegedly a rover test build for the mpi mini back in the 90’s, apparently thre were car5 stickers all over the parts when it was stripped.
Any thoughts, ideas, advice and heckling is welcome and appreciated, i will no doubt be pestering the life out of you all as the project progresses.
Thanks and apologies in advance
ianlighting
Has thanked: 162 times
Been thanked: 89 times
Re: Classic Mini (newbie)
Post by ianlighting »
This kit could give you some food for thought. Think they only sell it to businesses but it might be a good benchmark to measure against for your own DIY build…
https://www.fellten.com/system/mini
You might also find some answers using the search function here. There’s another site DIY Electric Car that might have some more answers aswell.
Has thanked: 83 times
Been thanked: 429 times
The outlander rear seems a sensible choice, depending on your goals.
Has thanked: 180 times
Been thanked: 372 times
+1 for outlander rear drive unit and OBC heck even the outlander battery if your on the budget end and don’t need too much range
ianlighting
Bigpie wrote: Thu Jul 03, 2025 2:45 pm
Nice little series there. Hadn’t seen that one before. With bonus special guest start Tom!
But where did they go after episode 8? Seems like they disappeared before the end?
Think they ended up going out of business.
ianlighting
Bigpie wrote: Thu Jul 03, 2025 6:53 pm Think they ended up going out of business.
Ouch. That’s a shame.
Has thanked: 209 times
Been thanked: 577 times
Yea they did could not get the right customers in the end and then kind of hard to keep going.
PEDR0
Post by PEDR0 »
Ive watched both, the opto mini turned out really nice, also read this through the build thread for this
viewtopic.php?f=12&t=6478
I really like the leaf platform but I don’t know how difficult it would be to split the contents of the top box (charger etc) so it wouldn’t take up so much room.
I’m also interested in the small rear tesla as i reckon it would leave loads of room in the engine bay for everything else
Has thanked: 418 times
Been thanked: 121 times
Post by Jacobsmess »
The leaf charger is massive and there are better options. The leaf "stack" can be separated into its individual components, but then you need to mess around with rerouting the HV connections.
PEDR0
Post by PEDR0 »
That’s what i thought, tremelune turned the inverter 90deg and used 3rd party gear to replace the leaf top box.
Key to all of this really is, whre are you based and what are the legal requirements when doing a conversion.
A leaf motor and drivetrain wont fit without subframe modification. So in some countries is not legal.
I would personally recommend the Outlander rear unit, I have been involved with a few mini conversions in the past (Fellten, Opto and others) and everybody get the level of power they think they want wrong. Builds with outlander rears run at 50% torque and that even can spin up the wheels.
ianlighting
PEDR0 wrote: Fri Jul 04, 2025 8:10 am I really like the leaf platform but I don’t know how difficult it would be to split the contents of the top box (charger etc) so it wouldn’t take up so much room.
For a tear down of the Leaf motor stack search Benjamin Nelson on YT.
For a complete dismantling of the Leaf PDM (top box) hunt for Johannes Hubner on YT.
PEDR0
Post by PEDR0 »
Thanks Ian, watched ben nelson, i’ll have a look at johannes. I think he does stuff with Damien(evbmw)
ianlighting
PEDR0 wrote: Fri Jul 04, 2025 10:16 am Thanks Ian, watched ben nelson, i’ll have a look at johannes. I think he does stuff with Damien(evbmw)
I think you might be right :)
In fact he might have set up this forum and the whole open inverter project!
As Tom said, outlander is the ideal set of parts for a mini, the gearing is also a bit better for the small mini wheels, compared to the other options. wiring and control is as simple if not simpler than the leaf stack!
Outlander rear du puts out lots of power, no weird subframe mods, pdm re wiring/ sealing, etc. and it’s all lighter weight than a leaf stack!
https://ebay.us/m/WiVxF0 if you're UK based then here's a cheap rear outlander motor.
Charger https://ebay.us/m/XmL2i6
And there's inverters going for around d £40-50 although might need to be checked for compatibility with zombieverter depending on year. Not sure if they're all compatible.
Alibro
Has thanked: 372 times
Been thanked: 223 times
Post by Alibro »
This guy did a nice job so worth a watch
https://www.youtube.com/@haand001
Jacobsmess wrote: Fri Jul 04, 2025 3:03 pm https://ebay.us/m/WiVxF0 if you're UK based then here's a cheap rear outlander motor.
Motor comes with drive shaft cups too! Nice
Proton
Has thanked: 188 times
Been thanked: 48 times
Post by Proton »
Do you need a board for this inverter/charger or it is working is.
The zombieverter can control the outlander over CAN for 70kw, others here (Romale I think) have done an OI board swap for up to 110kw I think.
PEDR0
Post by PEDR0 »
Alibro wrote: Fri Jul 04, 2025 3:59 pm This guy did a nice job so worth a watch
Yes, seen this also, I skipped the painting episode so didn’t realise it was an outlander
PEDR0
Post by PEDR0 »
Thanks to all for your help and input so far, going to be a bit of head scratching to do and then start collecting parts.
PEDR0
Post by PEDR0 »
So we’re all in on the outlander
Rear motor, inverter, charger purchased.
where are you based?
