Hello I want to use the 2012 civic hybrid ima motor with my own controller.
how do i wire the resolver? my controller supports encoder, hall and spi, uart, canbus, i2c
does anyone of you have a board to use the honda ima resolver?
thanks
honda ima motor resolver
- Has thanked: 4 times
- Been thanked: 3 times
Re: honda ima motor resolver
There is a fee openinverter 3 version It works well with the Honda Civic inverter, the resolver pinout can be found using a tester
