Ford Eluminator- have you got yours working?
52I
Post by 52I »
Have you had success getting your Eluminator running? Ford doesn’t appear to be supporting it and i haven’t found any electronics examples other than a few diy.
tmiit71
Re: Ford Eluminator- have you got yours working?
Post by tmiit71 »
Hi, I decided to go the Eluminator route as well after seeing AEM's mustang swap. Fuel2electric dot com is a good source of info as well.
Tutti466
Post by Tutti466 »
Hello, I am new to this. I just bought a Ford Mach-E motor and am just starting to look for components and everything necessary for my first project. I am not sure yet whether to use it in an early Bronco or a Mustang Foxbody, but that is the least of my concerns. I realize that there are not many resources available for working with this motor. Any help? Cascadian has theirs, but it’s crazy, 12k for an inverter. At least that’s what I think.
Has thanked: 368 times
Been thanked: 1536 times
The cheapest inverter solution will set you back around 400€ - that is Prius inverter gen2 or 3 with OI control board capable of around 400A on the AC side.
For about 100€ more you get a gen2 Leaf inverter with control board capable of 700A
https://openinverter.org/shop/index.php ... duct_id=57
https://openinverter.org/shop/index.php ... duct_id=63
http://evbmw.com/index.php/evbmw-websho ... ted-boards
Tutti466
Post by Tutti466 »
Do you believe that buying an inverter from the Mach-E and using a potentiometer could work? Or do you think it will come encrypted?
https://www.ebay.com/itm/364393365870
Falcemach1
Been thanked: 7 times
Post by Falcemach1 »
I have fitted an entire 2021 Mach-e system into my 1965 Falcon. I do have start-up issues but, I will sort that out soon!
anupraj
Post by anupraj »
I'm planning to use the Ford Eluminator motor for a project as well. Has anyone found a more budget-friendly solution for the inverter and control setup?
r1ckyb0nd
Post by r1ckyb0nd »
I am researching this a lot as I am in the planning stages of a project. It looks like the telsa model 3 rear drive inverter can spin other motors. This looks promising when they fully develop the openinverter board. The mach-e motor can go up to 210kw and it looks the m3 rdu can go upto 234kw so that would allow the use of all the power of the MME motor
r1ckyb0nd
Post by r1ckyb0nd »
I am starting to gather parts together to try and get one of these spinning. After reaserching this forum and other sources I am thinking the Chevy Volt Inverter in parallel will provide the necessary power. I am going to with Jack's board to control the inverter.
For the motor inwas looking at ebay, but they are the same price or cheaper from ford performance. Yes I know the ford performance is the front motor so it is missing the parking brake.
rgknaugle
Post by rgknaugle »
So are you using the Ford supplied VCU, and if so what software are you using to talk to it?
