[DRIVING] VW Touran powered by Nissan Leaf  [FINISHED]
Re: [DRIVING] VW Touran powered by Nissan Leaf
modellfan wrote: Thu Jul 25, 2024 10:30 am 255W * 256 kg * 0.90 J/g ° C for Aluminium gives you a temperature change rate °C / s
Oh thanks, that's something to play with :)
Shouldn't 256kg be in the denominator? Now I arrive at 58752 °C/s ;). With 255W/256000g * 0.9 * 2h I arrive at 6.4°C rise in 2 hours, of course neglecting heat exchange with the environment.
Or 15 minute 185A charge 2400/256000*0.9*15*60 = 7.6 °C.
Both figures seem a bit low, especially the second one so I guess there must be additional losses. Could indeed be the bus bars and cable interfaces.
Concerning overshoot I see about 0.5-1°C rise after ending the charging session. So there is some delay but it doesn't seem to critical. I guess the temp probes are strategically placed.
modellfan
Has thanked: 20 times
Been thanked: 61 times
Post by modellfan »
mea culpa.
255 J/s
--------------------------- = 255 / 256 /900 * °C/s = 0,0011 °C / s = 4 °C / h
256kg * 900 J/ (kg * °C)
2400
---------------- * 15 * 60 = 9,4 °C / 15min
256 * 900
I understand, this is only for the internal losses of the battery. What is the total voltage difference between charging voltage and sum of all cell voltages ? Propably there are voltage drops in the bus bars and screwing connections.
Luckily I made a video :)
Seems like 4V @ 220A. From all I know this includes the voltage drop over the dispenser cable as well.
I decided this needs more data. So I went to a V4 super charger and charged for 10 minutes from 35 to 58%. Outside temperature was 23°C and fan running at full speed.
Raw data is attached, here is some plots
Voltage drop is lost in measuring accuracy. It was always less than 1V. You can see the CCS value only has 1V resolution, thus the steps.
Cell delta is adorable, never seen cells so well matched. Maximum was like 10 mV
Temperature rose from 23 to 37°C in said 10 minutes
The difference in voltage from 0A to 200A is 16V or 169 mV at cell level. That would be 80 mOhm for the whole pack and 0.845 mOhm per cell. Close to spec of 0.74 mOhm.
When turning off we see only 7V drop from 168A to 0A. That would point to half the resistance, 41 mOhm. Probably because we are now at 37 °C.
I remained stationary for a minute after charging and the temperature rise immediately stops or maybe increases by 0.5°C
So now we have lower resistance than assumed but higher temperature rise (despite fan) than calculated. Hmm
EDIT: wait, I charged at 200A not 185A. So 200²*0,08/(256*900)*15*60 = 12.5°C. Still lower though
I'm now recording the cool down over 2 hours with fan running.
EDIT: here is the cooldown over 80 minutes
test.csv
(227.23 KiB) Downloaded 635 times
2024-07-25 drive and charge.ods
(295.74 KiB) Downloaded 651 times
Has thanked: 330 times
Been thanked: 848 times
You are not really drawing air past alot of surface to absord the heat. ideally you would thermally bond on more "fins" to create surface area.
What material is you battery box? It might be worth trying to couple the modules to that so the neat gets out of the box easier.
The battery box is aluminium. The plan was to do just that but I screwed up. The distance between the upper modules and the box is 3mm :? It's super hard to get everything out again.
The lower half I have more of a chance. They don't touch the cover plate at all. I would like to add something soft that conducts heat. That way if something hits the cover plate it doesn't immediately propagate to the module
modellfan
Post by modellfan »
We are now about 14 C measured compared to 12,5 C calculated, right ? What I gave you with 900 was the heat capacity for Aluminium . NMC s are in literature with 800-1000. I think measured current and voltage loss is better then internal resistance as this changes much more over time .
Other effect ist, where the temperature is measured. Maybe just 180kg needs to be fully heated until it reaches the sensors. Really depending on the internal design of the modules and the heat transfer between different layers eg cell chemistry and Aluminium housing.
Interesting to see , that for high charge power and short term , voltage losses are dominanting the convection.
modellfan
Post by modellfan »
Would be interesting to fit your data to a curve . But before maybe you should improve the cooling of your battery. Losing 2C in 80min with the heat capacity formula you can calculate the energy dissipated by convection.
For convection https://www.schweizer-fn.de/stoff/wuebe ... g_gase.php . With one square meter and 14C delta to outside you should could down 5 * 14 * 1 W = 70 W . That is just really low compared to energy losses
Yes 180 kg would be plausible as each cell is less than 1 kg and there are 192 of them.
"Flying Tools" youtube channel once ripped apart an MEB module and the modules are thermally connected to the bottom plate mostly. That is the issue:
I'm blowing in air through 2 small holes (40mm) where the middle BMS cables are and the air exits where the outer BMS cables are. A lot of the pressure leaks out elsewhere. Compared to the humongous air flow this fan generates only a tiny breeze is left on the exit pipes. Like enough to blow out a candle.
So issues
- Air flow limited by hole diameter
- Air leaks out before getting to the batteries (could be fixed)
- Air only flows via the top surface of the module that is not thermally bonded directly to the cells
- It's unclear where the air stream goes past
Mathieu already suggested to make vent holes in the back of the box to have a cleaner, higher volume air flow. I'm really afraid to add new holes and possibilities for water ingress though. Plus I might drill into the module when making the holes.
Aragorn
Has thanked: 6 times
Been thanked: 66 times
Post by Aragorn »
Can you not get a cooling plate sandwiched in between the modules? Something like a slab of aluminium with some copper pipe embedded into it that you can pump water thru....
Theres good reason everyone has water cooled batteries now ;) Especially if your wanting to push charging rates up beyond the 40-50kw range that the earlier EV's were limited to, which appears is the case here...
I dont think air cooling is going to do much, without properly ducted airflow and cooling fins. Theres just no surface area.
Yes I had indeed planned to use VWs water cooling plates but then shoehorning reality got in the way ;)
For one I have very little space to play with. So Fitting 1 plate per "floor" is not possible. Sandwiching one between the modules would be the only possibility but for that to make sense I'd have to turn them upside down. That in turn would complicate the top-bottom bus bar connection but most of all the cable exit.
Given the terrible accessibility now that is what I'm stuck with, no point in "should have done" philosophy ;)
Please add to the list to improve long range ability:
- Reduce charge speed
- Improve air flow
- Improve contact area of modules to box
Been thanked: 413 times
You got me thinking on 2 plans that do not include water...
1. Use of AC plumming to pump heat out of central alu plate. You would have to make an alu plate 8mm, cut 8mm grooves and fit (beat in) a copper tube in alu plate. This will chill cell.modules on both sides. You would just have to turn them with lower side inwards.
2. Make an air chiller. You would still have to reposition modules for best cooling...
A friend working with inox was hired to make a compressorless chilling room where air would be lower than 8deg... reason for that was constant breakdown of ac compressors for chilling.
Well he used full room length and made a lot of channels through where he fed air from blowers. He managed to get room to 5deg!
Maybe you could make such low crosssection channels (10mm) on the sides of the battery assembly and drop temp by airflow? This would mean you would have to make at least 2x NACA style manifolds in front to attach blowers to it. Then you can maybe make sidewall taper at the back, maybe taper 10mm to 5mm spacing, so to keep the airflow laminar and keep air speed increasing along the modules sidewall. You think it would work? I think this would mainly require some aluminum to form channels and some welding to form manifolds to fit blowers to.
Tell me more about making an air chiller! If I could produce air with lower temperature than ambient plus improve air flow it could at least allow for one full charge session per day, equating to 500-600 km relaxed driving.
Going back to air cooling the Nissan pack which wasn't fully encapsulated (thus making me nervous in heavy rain) and was fitted with a small fan stopped overheating. In a way it had better long range ability than the MEB pack, because it cooled down 10-15°C between charge sessions.
johu wrote: Sat Jul 27, 2024 4:03 pm Tell me more about making an air chiller! If I could produce air with lower temperature than ambient plus improve air flow it could at least allow for one full charge session per day, equating to 500-600 km relaxed driving.
Well...
The idea with the room was to have so much alu fins to create slots where air would move with really high velocity. At the same time the slots would reduce in size to cause the air layers to compress which would increase the air speed even more (at constant pressure). Air moving so fast would remove temperature from the fins and at the end of the room there would be large heat exchanger (medium unknown) which would interface with other room where the products requiring would be.
In your case i would imagine the chilling medium would be simply air. I have recomendations:
1. Create slots over your battery modules with clear air path on two oposite sides of the battery from intake to exhaust.
On intake side slot would be maybe 3cm wide 1cm. On the exhaust i would imagine 2cm 1cm or even less.
EDIT: for construction stifness i would use longerons in the direction of air travel which would be riveted to aluminum cover. I dont know about the side of the modules. I imagine air should be traveling over modules directly. In that aspect you could even install the air duct to the battery cover directly. If you think of your battery box structure as carrying then you should build the air duct inside your box and fasten it to the box with opening for intake and one slot for exhaust on the other side.
2. On each intake you would want to place one or more centrifugal blowers and form the slots to be connected to blowers exhaust as directly as possible. Centrifugal blowers should be of a sealed type so you could install them under chassis.
So as to be no misunderstanding, i do not imply you should make slots on our box where air would enter directly while driving! Not at all! Blowers should provide air motion and slots should be sealed by rubber seals.
3. On the slot exhaust side you could create a downward facing hatch so any moisture freewheeling there would be deflected downwards/outwards.
In any case i would suggest to have this system operating whenever you would be driving or charging so as to remove moisture from the battery as much as possible.
Whenever you use air it is inevitable you would get moisture inside your system. To fight that you could seal the modules BMS connector slots with silicon goo or that black engine head gsket goo...
EDIT: I would think one does not need to get lower than outside air temp, simply lower than 42deg that battery chemistry finds offending. This means you need to counted the temperature gradient towards the battery center with one towards the outside.
For that i would think best way would be to fit the air slots to the bottom and the top side of your pack. Keep the air moving fast and along the whole side of the pack. Then exit from a slot that is downward angled at your current inox wall. You would need to play with angle grinder to create the slots at the front and back. But you need to make some standoff fittings on the sides so you can raise and lower the top nd bottom sides. Would that be doable?
barracuda816
Has thanked: 75 times
Been thanked: 23 times
Post by barracuda816 »
Have you thought about Peltier plates? Horrible efficiency but could be of use only during charging for example. Only a few mm thick and easy to control and they can pump some heat if you pay attention to the deltas.
Has thanked: 365 times
Been thanked: 249 times
Post by jrbe »
arber333 wrote: Sat Jul 27, 2024 7:35 pm Well...
The air needs to be at a lower temperature than the fins to move heat. Just blowing the same temperature air over fins of the same temp will do nothing for lowering the temp.
Did your friend make a vortex tube to "split" the heat out of the air? These are like the cool tube for old be beetles. Otherwise I'm not getting where the temperature drop is coming from in your descriptions.
jrbe wrote: Sat Jul 27, 2024 8:41 pm The air needs to be at a lower temperature than the fins to move heat. Just blowing the same temperature air over fins of the same temp will do nothing for lowering the temp.
Well what can i say, i wasnt the one that built this. He told me about the results and what mattered the most, customer was satisfied!
The main think was get the exchanger to correct temperature without moving parts - AC compressors etc...
How the exchanger would get to lower temperature i would imagine by sheer surface of fins in moving air.
He said the slot distance was key, also air neded to be kept laminar the whole way, that is why the convergence in slots.
Now you got me thinking on details... i will go and ask him directly, after vacation...
EDIT: I would think one does not need to get lower than outside air temp, simply lower than 42deg that battery chemistry finds offending. This means you need to counter the temperature gradient towards the battery center with opposite one towards the outside.
barracuda816 wrote: Sat Jul 27, 2024 8:37 pm Have you thought about Peltier plates? Horrible efficiency but could be of use only during charging for example. Only a few mm thick and easy to control and they can pump some heat if you pay attention to the deltas.
For the battery mass you are talking about you would need a huge lot of them... and where to get the energy to power the heat pump? And where to dump it to...
Or you could simply make the box sealed, cut some slots at strategic places in front and back and fit the blowers with some filter to your assembly. You would blow air INTO the pack, create positive pressure and dust and moisture would go out :).
I would imagine correct size of blower should be your veritable cabin air blower assembly! As it normaly comes with filter you could just use it with OEM channel if you have the space.
From your photo the sides are where the air should move unimpeded but i think you should make standoffs on the upper as well as lower levels. Even 3mm would help i think.
Some blower suggestion....
https://www.ebay.de/itm/201955251263?ep ... R-rnneKeZA
Then there is an option of suction fan...
Like before you could create openings for air to enter into your box (through some filter prefered...) and a chamber made to mount suction fan on another end of the battery box. This would suck the air from one side to the other and ideally create enough current to chill whole battery assembly.
...careful with negative pressure, you would need to put some stringers into your battery on top and bottom so that it would keep the form of the slot through air would flow under suction.
If there is too much negative pressure you could deform your case!!!
Also with suction it is more likely to gather dust and moisture inside the pack...
I would suggest you form your intake as a prism with opened bottom, where air will enter from and where you fit your filter. It tapers towards top and you could mount it to your front side. You would just need to make your existing front side full of holes :).
If you dont like the idea of filter you could also put a flap into the intake assembly to act as inertial separator which would separate sand and heavies particles...
https://www.bgaerospace.com/2019/12/04/ ... separator/
Suction fan example...you could use multiple fans...
https://www.ebay.de/itm/386324117630?it ... R9TD4-KeZA
barracuda816
arber333 wrote: Sat Jul 27, 2024 9:17 pm For the battery mass you are talking about you would need a huge lot of them... and where to get the energy to power the heat pump? And where to dump it to...
It's not so much about the battery mass more the heat generated. But yes, at a guess and without doing any calcs you would need a fair few of them. However even if you did a trial of 10 large 100w that's only one 1kw when being used when charging or under regen only the efficiency matters less. I don't know much about the MEB module packaging but if they already have heat spreaders then they could be directly attached with thermal conductive adhesive to the cold side and if room allows then water blocks to dump the heat externally, or straight into the aluminium battery enclosure (obv not as good) but I am thinking the box isn't getting any where near the temp of the modules at the moment so the "problem" is heat transfer out of the modules.
I think chilled air cooling with ducting would be a better solution but as a proof of concept it probably doesn't get much cheaper and quicker than Peltier modules.
barracuda816 wrote: Sun Jul 28, 2024 9:47 am ....
I tried CPU cooling with peltier via alu ribs on the other side and water block instead. What i found was how much peltier can chill the primary side, but likewise how quickly can the other side warm up. And then you must remove that heat quickly. dT would stay the same but core on one side would heat up and destroy peltier as it is still semiconductor...
Water chiller was best in my case, but it required plumming and heat exchanger on the other end.
I am noticing now with all those graphic cards cooling bridges they use heat pipe chillers which move dT away from the chip and dissipate it in the moving air... That was my idea regarding AC piping where you would remove heat from the batery and transfer it up front by gas medium.
But in our case, best is the simplest and i think suction fans would work best here. Cooling slots are already formed, all you must do are front and back receptacles.
Post by jrbe »
40mm isn't much to get good airflow. A vortex tube with a tiny rocker compressor or rotary vane compressor feeding it could work well to feed very cold air in.
I like the Peltier idea but it would either be a ton of modules, say 1 for every 2 or 4 cells depending on how you can place them or heat spreaders that there likely isn't room for. The heat could dump to the battery box shell. And they typically have a high max temp of 200°c, they usually die prematurely from pulsed power.
Using thermal transfer pads to the battery box could be another solution. The bottom of the battery may have been designed for good thermal performance but the top or sides might be enough to be useful as well.
But there's the condensation issue to consider with any cooler than ambient solutions. You'll need an effective way to keep moisture out that lasts a long time. It's not easy.
Peltier could be a sealed box with silica gel where it can fit and be checked occasionally if you can seal the box.
The vortex tube could use the same air in an enclosed battery box but pump the hot air through a cooling loop that gets routed outside the box to dump the heat elsewhere. Same silica gel to help humidity inside.
https://www.vortec.com/en-us/enclosure-coolers
jrbe wrote: Sun Jul 28, 2024 11:14 am The vortex tube could use the same air in an enclosed battery box but pump the hot air through a cooling loop that gets routed outside the box to dump the heat elsewhere. Same silica gel to help humidity inside.
Now that is an idea! Silica gel in strategic places would dry air in those places.
I dont know vortex coolers, i woould have to read more about it.
To me it seems best solution is the simplest. So for now making two front/rear covers from alu sheet metal and mounting a filter in front and suction fan at the end sounds like viable option.
Then test this to oblivion and report back :). If results are not up to requirements then move to more difficult $$$ options.
Post by jrbe »
And thinking through this further, the silica gel could likely be enclosed in the hot side and be mounted external to the battery box to swap it easily if necessary. You could likely add a humidity sensor in the loop to keep an eye on things. This enclosure could be typical plumbing components with a screw cap. I forget if it's the Prius or the leaf that has a tall cylindrical desiccant pack (as the receiver / dryer) that could be used for this (as well as many other options as well.)
