I would like to know if this is possible with FOC firmware.
Initially there is something that I don't see how to solve, because in the motor resolver connector there are 6 cables (R1, R2, S1, S2, S3, S4) and on O.I. mainboard v3, I only see 4 entries in JP2:
pin1=S3
pin2=S1/S4 (two wires from motor?)
pin3=S2
pin4=R1
Where would R2 go?
Besides this, does anyone see any other problems?
outlander rear motor + openinverter board ?
- Has thanked: 22 times
- Been thanked: 130 times
Re: outlander rear motor + openinverter board ?
Schematic suggest R2 goes to GND.
https://openinverter.org/wiki/File:Main_board_v3_.jpg
- Has thanked: 134 times
- Been thanked: 335 times
Yes R1 is the excitation signal into resolver core. R2 is just the other side. But it has to go to GND on the side of OI board!royhen99 wrote: ↑Thu Oct 26, 2023 10:50 pm Schematic suggest R2 goes to GND.
- Romale
- Has thanked: 307 times
- Been thanked: 77 times
did you manage to find all the pin values on the standard board of the rear inverter in order to connect the OI board to it?chentron wrote: ↑Thu Oct 26, 2023 10:36 pm I would like to know if this is possible with FOC firmware.
pin1=S3
pin3=S2
pin4=R1
Where would R2 go?
evil neodymium
