Thanks, Roy. I reduced the hysteresis but then realized all the time I've spent sitting out here with the charger plugged in has led to me being 4.15V lol. So I guess I'll have to drive it to work tomorrow and try again when it actually needs a charge.
Simp BMS
- vwbrady
- Has thanked: 5 times
- Been thanked: 11 times
Re: Simp BMS
- Has thanked: 103 times
- Been thanked: 216 times
- vwbrady
Re: Simp BMS
I've not been able to get the charge enable output to come on until the tip from Roy, so no I guess it doesn't!
BTW I'm using a Chevy Volt charger—the one with the PWM control input.
Re: Simp BMS
You are responsible for the design in the end of the day, if the BMS has no way of interacting with the charger and stopping it that is up to you.
I do not know how you are controlling it with PWM, I would highly recommend having something look at the can bus messages from the SimpBMS and set target voltage and current. Once Current goes to Zero switch the charger off and also possibly look at the 12V output for charge enable.
There are alot of ways to integrate it all, there is alot of emphasis on letting the installer define his or her own system setup and take the final responsibility for functionality and safety.
- vwbrady
Re: Simp BMS
I am aware and comfortable with the risks I take.tom91 wrote: ↑Wed Mar 08, 2023 9:39 am You are responsible for the design in the end of the day, if the BMS has no way of interacting with the charger and stopping it that is up to you.
the GM Volt charger is PWM controlled along with a 12v enable, no CAN. There is a PWM status output that tells you voltage but I haven't bothered with that much. The simp BMS is now controlling the 12v enable on the charger.
New challenge is figuring out why the nextion display only updates data when it's power cycled. The SoC doesn't change but the voltages do. So while i'm driving I have to watch voltage to see SoC.
Re: Simp BMS
Okay that is weird as it does get broadcast as you can see the voltage change. Can you confirm which display file and SimpBMS firmware you using?
- vwbrady
Re: Simp BMS
I purchased the setup through kitoffgrid like 2 years ago and haven't updated any firmware. I'll take a look and maybe record a short video when I get home.
- vwbrady
Re: Simp BMS
it's hard to see in the video, but the display is V1.0.0
video shows the key cycle that updates the SoC meter. The photos are the SoC and voltage prior to trip.
Re: Simp BMS
Please update the BSM firmware according the instructions in the end of the user manual: https://github.com/Tom-evnut/SimpBMS/bl ... 0V0.29.pdf
Alot has been updated since the firmware version 28818
- Has thanked: 49 times
- Been thanked: 10 times
Re: Simp BMS
Hi, it appears the outlander charger has just been added to github five days ago by jamiejones85, big thanks !
There was 1 error in the ino file while I was compiling it:
I changed it to case 8 on the outlander charger part and then it compiled perfectly.
I don't have github account, please someone check and correct this.
the error is located on line 2758 in https://github.com/Tom-evnut/VW-bms/blo ... .ino#L2758
case 7:
SERIALCONSOLE.print("Pylon - TESTING ONLY");
break;
case 7:
SERIALCONSOLE.print("Outlander Charger");
break;
- Has thanked: 75 times
- Been thanked: 304 times
Re: Simp BMS
oops, I'll sort it out, that jamiejones85 guy is useless
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
- andybpowell
- Has thanked: 192 times
- Been thanked: 227 times
Re: Simp BMS
just make sure you don't kill your teensy3.2, have you seen how much they go for if you can find one
https://www.ebay.co.uk/itm/185811335949
- Has thanked: 39 times
- Been thanked: 45 times
Re: Simp BMS
Anyone successfully using the Simp BMS with the 7s Tesla module packs from a B250e or Rav4?
Building: 1964 International Scout 80. LS600H transmission with zombieinverter, B250e battery pack
Re: Simp BMS
Will add to my GitHub and link it here later but my implementation of the outlander charger is slightly different (I use the bmw phev bms but the main loop doesn’t differ much) I have added a wakeevse function called by cell voltages < charge set point which just sends the 285id message to wake up the evse meaning 240v is available to a relay to set (IN3) high and change bms status to charge (if other conditions are met) and calls the chargercoms function and send the 286id message to set charge current.
I found this the easiest way to initiate charge, keeping both can messages in the chargercoms function means you need some other way other than ac present to enable charge.
It’s probably not the most elegant solution but it worked for me
- Has thanked: 46 times
- Been thanked: 15 times
Re: Simp BMS
Is the isolation monitoring (HV to chassis leakage) a feature that is available with the SimpBMS?
Re: Simp BMS
No its not as it requires specific and dedicated hardware. I have provided support of a chinese Isolation monitor and the Bender solution in my new product EVS-BMS. Can add it to the SimpBMS if required.
Re: Simp BMS
What's the Chinese isolation monitor? The outlander one looks pretty standalone from memory but not sure if anyone's done anything with it. I've got a couple of the GTE boards that can do it, but not tried to figure out how they work.
VW Beetle 2003
Outlander charger
Chademo Charging
Outlander charger
Chademo Charging
Re: Simp BMS
A unit like this one https://www.aliexpress.com/item/1005005 ... seXAoHNSBX
Managed to get a few cheaper direct from supplier but still not cheap. https://cqbluejay.com/product/gyid-ev-dmd/
Re: Simp BMS
Yes, please do add it to the SimpBMS. At least it will be an option.
Is it hardware or software update?
Re: Simp BMS
as promised BMWphev - outlander charger
I haven't forked due to the fact i'd like to keep it separated until someone else confirms they are happy with the implementation, i kinda just copied Jamie's spaceballs code where needed (so we also get charger info in the serial terminal) but like i said above Isplit the can messages apart to use one to wake up the evse before entering charge status.
https://github.com/EV8-Steve/SIMP-BMS-.git
Re: Simp BMS
You need to purchase hardware to make it work, it is over canbus. I might have one I can sell you, please message me if interested.alexbeatle wrote: ↑Sun Apr 09, 2023 11:05 pm Yes, please do add it to the SimpBMS. At least it will be an option.
- Has thanked: 249 times
- Been thanked: 62 times
Re: Simp BMS
Any chance of getting this to work with IPace modules? I'm wanting to break a pack down for a more usable weight/size but I'm not sure how I'd go about controlling the 78S (26 modules) configuration without purchasing an expensive BMS.
Re: Simp BMS
I have not had the chance of working with the Ipace slaves, so cannot tell you how much effort this would be.Jacobsmess wrote: ↑Wed Apr 12, 2023 6:48 am Any chance of getting this to work with IPace modules? I'm wanting to break a pack down for a more usable weight/size but I'm not sure how I'd go about controlling the 78S (26 modules) configuration without purchasing an expensive BMS.
Where are you based? I could look at adding the functionality into the EVS-BMS and open sourcing the info in the SimpBMS format. I currently do not have any SimpBMS due to the missing Teensy 3.2s.
