Gen3 inverter connector (not unobtainable)
bexander
Has thanked: 63 times
Been thanked: 89 times
Post by bexander »
Regarding the Gen3 inverter connector that used to be unobtainable can in fact be bought.
https://openinverter.org/wiki/File:Priu ... _Body_.jpg
The housing can be bought from Toyota, cost was 89 SEK (~€8)!
Then terminals and wire seals are needed and after some web searching and testing I have concluded this BOM:
Connector housing:
Toyota G9260-47010, 36p
Toyota G9266-47010, 13p
Small terminal, 0.64:
0,22-0,35mm2
TE 1612290-1 (tested ok)
Sumitomo 8100-3455
Small wire seal:
Sumitomo 7165-1198
Small blind plug:
Sumitomo 7165-0797
Large terminal, 2.3:
0,3-0,5mm2
Yazaki 7116-4025 (tested ok)
Sumitomo 8100-0460
0,8-1,25mm2
Yazaki 7116-4026
Sumitomo 8100-0461
2,0mm2
Sumitomo 8100-0462
Large wire seal:
Sumitomo 7165-0342 D4,9mm d1,4-2,0mm
Sumitomo 7165-0343 D4,9mm d2,0-2,5mm
Sumitomo 7165-0344 D4,9mm d2,5-2,9mm
Large blind plug:
Sumitomo 7161-9787 D4,7mm
Terminal extraction tool
0.64 Terminals : Sumitomo 3070000 or 307-0000-03
2.3II Terminals : Precision screwdriver(1.2mm~1.6mm)
NOTE: The Sumitomo terminals are not tested but thay look the same as the ones I have tested and documents point to the Sumitomo extraction tool, hence my guess is they will fit as well.
bexander
Re: Gen3 inverter connector (not unobtainable)
Post by bexander »
Updated first post with part nr for the small 13p connector housing that clicks into the larger 36p connector housing.
