I can confirm that as of version 1.10A, the inverter communication and motor control works correctly.
However, battery charging with the PDM is not working. When an EVSE is connected, it is detected and the mode changes to AC charge as expected. The VCU performs a precharge and closes all contactors as expected.
However, it then immediately reverts to idle and opens contactors again. This process repeats in a loop as long as the EVSE is connected. Attached is a chart showing the mode, charge mode, and bus voltage, demonstrating the problem.
Configuration is as follows:
CHGMODS=2=EXT_CAN
CHGCTRL=0=Enable
CHGINT=3=Leaf_PDM
