LDU parameters showing reverse when in forward
Roadstercycle
Post by Roadstercycle »
Trying to make sense of what's happening here. When motor going forward it shows reverse on parameters page on laptop. When in reverse it shows forward. Even trying to use the button swapped setting on perimeters page it shows the same thing. Should I just ignore it or is there a reason or a fix? I do refresh the page after each change to let the new input show up. I'm using 5.20 firmware.
jon volk
Re: LDU parameters showing reverse when in forward
Post by jon volk »
I'd just ignore it. Mine has always been swapped.
Boxster EV
Has thanked: 57 times
Been thanked: 48 times
Post by Boxster EV »
Roadstercycle wrote: Thu Nov 24, 2022 7:29 pm Trying to make sense of what's happening here. When motor going forward it shows reverse on parameters page on laptop. When in reverse it shows forward. Even trying to use the button swapped setting on perimeters page it shows the same thing. Should I just ignore it or is there a reason or a fix? I do refresh the page after each change to let the new input show up. I'm using 5.20 firmware.
How have you found the new firmware?
Roadstercycle
5.20 firmware here. https://github.com/jsphuebner/stm32-sin ... /v5.20.R-2
catphish
Has thanked: 96 times
Been thanked: 188 times
Post by catphish »
The SDU has always run backwards, so I guess the LDU is the same. Forward and reverse function exactly the same, so just ignore it.
