E Golf Battery pack
jeltop
Re: E Golf Battery pack
Post by jeltop »
arber333 wrote: Tue Nov 15, 2022 8:57 pm In my opinion you should reconfigure modules from 12S into 16S configuration. That way inverter will work at higher battery potential.
As i have Volt battery 12S with my solar setup i am seeing some adverse behaviour as inverter has 48V minimum for change from utillity.
If i would be able to use higher cell count i could setup for it to move in higher voltage range.
hi
What do you mean? I am a beginner, 12S and 16S what is it exactly?
how can i test if the batteries are still good or dead? because I bought it second hand
I take a 12v car charger and I plug into a module for example, to see if it charges? thank you
thank you
Alibro
Has thanked: 265 times
Been thanked: 149 times
Post by Alibro »
jeltop wrote: Wed Nov 16, 2022 7:27 am hi
thank you
12S is the number of cells in series. 2 or 3P is the number of cells in parallel.
These are lithium ion batteries. Do not use a battery charger designed for lead acid batteries to charge them as it will destroy them.
If you have never used lithium ion batteries before then I'd recommend you do a LOT of studying before going any further or you risk damaging the batteries at best and burning down your house at worst.
I need a bigger hammer!
JaniK
Has thanked: 49 times
Been thanked: 10 times
Post by JaniK »
I have a small issue:
Module #8 was bench tested and working as a 10S group CAN module before. I have a screenshot from SimpBMS to verify that.
Yesterday I plugged in CAN modules 5/6/7 and 8
(With the cell interconnect wiring for their respective cell Groups.)
The module #8 is not Sensing/sending voltages from cells 9 and 10. I tested another cell interconnect cable and issue seems to not be between cell taps but in the CAN bus module #8.
All other CAN modules work fine.
I hope the module is not changing its behavior related to other modules sending some ids, since I am re-using the original VW CAN-bus harness. With the enable and can lines running through the other modules.
boekel
Been thanked: 11 times
Post by boekel »
JaniK wrote: Tue Sep 19, 2023 8:03 am I have a small issue:
that is correct, the old version (Panasonic) was able to sense 12s on all CMU's, the Samsung version cannot sense more cells than originally in the pack.
iirc 3 CMU's are not capable of 12s.
