Eltek 360 HV chargers
Has thanked: 80 times
Been thanked: 233 times
I pulled Eltek chargers from my car now. Interested? They work up to 420Vdc and are programmed for different addresses 0x300, 0x310 and 0x320. But they also work with 0x2FF command. Liquid cooled and easy to setup
I offer single charger for 600€ and 2x for 1000€.
I would offer all 3 but one is reserved for Johannes :).
Some photos will follow...
BR
Arber
Re: Eltek 360 HV chargers
I offer single charger for 500€, 2x for 900€ and all three for 1200€.
They are liquid cooled CAN controlled preprogramed to each own ID.
DC connection remade with MC4 solar connectors
CAN lines terminated to 3p sealed Denso 2.0 connectors
AC lines are free, left for you to terminate them...
Zapatero
Has thanked: 25 times
Been thanked: 39 times
Post by Zapatero »
Hi, are these still available?
Zapatero wrote: Fri Nov 25, 2022 11:50 am Hi, are these still available?
Yes!
If you want all three of them, for the price i can add my new VCU that can link them to EVSE, BMS etc...
https://openinverter.org/forum/viewtopi ... 605#p47605
Zapatero
Post by Zapatero »
I'm taking all three of them!
Zapatero wrote: Sat Nov 26, 2022 4:48 pm I'm taking all three of them!
Done!
boekel
Been thanked: 11 times
Post by boekel »
If this is sold, I've got 3 more watercooled ones, one of them had a small nick in the housing that I fixed.
came straigt from dismantled cars, I haven't used them (used air-cooled ones but didn't have much luck with these)
any reasonable offer will do, shipping is from the Netherlands.
They are reserved...
Chargers went out.
I still have 2x Eltek chargers that i whish to sell. If you are interested i sell them for 400€ each
One is modified for liquid cooling from aircooled rack Eltek into Volvo housing
https://leafdriveblog.wordpress.com/202 ... d-cooling/
The other is OEM Volvo Eltek
https://leafdriveblog.wordpress.com/201 ... w-charger/
I have shortened cables on both and fitted solar connectors so they are waterproof and polarity cant be switched.
Chargers are reprogrammed so they work at individual addressing, but they respond to common ID 0x2FF telegram.
