I tried connecting the + charger to different phases while keeping the minus of the charger on the minus of the battery. the contactor between the inverter and the battery was closed and the inverter showed the "boost" status, but there was no charging current in reality. these experiments were on the firmware 5.14 foc. tomorrow I will check for 5.21 fok. it seems to me that the fact that my battery is only 120 volts matters and a different setting is needed somewhere.remy_martian wrote: ↑Sat Aug 06, 2022 8:21 pmWhat happens when you move the "charger out" positive wire from the blue to the green or red motor phase?
Maximum achievable charging power with an inverter
- Romale
- Has thanked: 214 times
- Been thanked: 49 times
Re: Maximum achievable charging power with an inverter
evil neodymium
- Renegate2020
