Parameter database
- Has thanked: 154 times
- Been thanked: 960 times
Re: Parameter database
The token parameter isn't mandatory. Can you post a screenshot where you're stuck?
- Has thanked: 74 times
- Been thanked: 299 times
Nevermind, it's worked today, the add.html page wasn't loading :S
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
Having issue updating a parameter set. "Parameter ID Not Found"
Edit, seemed to work after a few tries. Not sure what I did different.
VW Beetle 2003
Outlander charger
Chademo Charging
Outlander charger
Chademo Charging
I've downloaded my latest param.json but cant see how to update it from the website without going through the inverter UI. Is this possible at the min?
VW Beetle 2003
Outlander charger
Chademo Charging
Outlander charger
Chademo Charging
Had to check the code again. Seems the "Add Parameters" function doesn't expect the params.json but rather the output of 192.168.4.1/cmd?cmd=json%20hidden
Needs clarification I suppose...
