Gen 2 Chevy Volt cabin heater
TonyV
Been thanked: 12 times
Post by TonyV »
Does anyone know how this heater is controlled?
I have search on Google and here but there is very little info.
Can someone point me in the right direction?
Has thanked: 368 times
Been thanked: 1536 times
Re: Gen 2 Chevy Volt cabin heater
It's not yet documented but the ZombieVerter VCU can control with via a 33 kbps onewire CAN bus
Has thanked: 134 times
Been thanked: 335 times
I have made some research on Volt gen1 heater which is Eberspracher made with sw can bus. I personaly didnt run it yet but i saw Jack Rickard got it to run as well as others...
https://leafdriveblog.wordpress.com/201 ... ic-heater/
http://s80ev.blogspot.com/2016/12/the-heat-is-on.html
TonyV
Post by TonyV »
Thanks guys!
Dlud
Has thanked: 4 times
Post by Dlud »
Tony, did you ever get your gen 2 Volt heater controls worked out?
TonyV
Post by TonyV »
Sorry no i haven't.
Got it installed but just have reached the point yet where i need to dive in deeper.
But from Jack Richards video its a single wire canbus. and I guess you will need a Single wire controller. :?
Good luck.
Tony
