Idle Rpm ZombieVerter.
Khallie06
Post by Khallie06 »
Hi all, new to the forums here, I'm currently planning to covert a 2009 insignia to electric with a leaf motor and Inverter.
I want to use the tachometer on the oe dashboard for motor speed.
Is there an Idle Speed configuration in the ZombieVerter VCU? That way all I would need to do is mount the tone ring and sensor onto the output shaft, or would I need to emulate the 60-2 pattern using a Microcontroller and translate the pwm out from the VCU to the oem Diesel ECU?
