In a recent hunt for components, I came across a accident damaged E350e, and wondered if the components would be usefuk for anything.
After a quick bit of research, I discovered that the electric motor is about 60 kW, and sits between the motor and 9 speed gearbox, and it has around a 6 kWh Li-Ion battery.
Has anyone else played with such a setup or used it for parts?
Jamie
