EV car conversion hardware
- muehlpower
- Has thanked: 12 times
- Been thanked: 103 times
I have a similar problem, I need longer cables on the motor. My 70mm² cable has a larger outer diameter than the AWG 2/0. I will make stainless steel parts to make it fit.
- Has thanked: 103 times
- Been thanked: 216 times
I am also working on some adapters that we hope to sell at Zero-EV. Utilising gland components to work with 70mm2 or 50mm2 shielded cables.
Just got confirmation from Zero-EV that they expect to have these available in the next couple of weeks.
I'm on the notification list, very excited about this. Thanks @Tom91, appreciate it!
- Has thanked: 80 times
- Been thanked: 233 times
I have found an alternative for brake vacuum switch. It is variable. Anyone knows about that?
It looks robust enough... https://eveurope.eu/en/product/vacuum-switch/
- muehlpower
I have one here but I haven't tested it yet. It is a MA-TER XV600. I bought it here for € 27.50:
https://www.ebay.de/itm/382775703794
you can buy it also at conrad electronic:
rubbercab Bestell-Nr.:583807
switch Bestell-Nr.: 583795
OK, i see they have also a rubber cap to protect against moisture. Nice inclusion.muehlpower wrote: ↑Wed Jul 29, 2020 9:30 am I have one here but I haven't tested it yet. It is a MA-TER XV600. I bought it here for € 27.50:
https://www.conrad.si/gumijasta-zascitn ... 0090-mater
I will order and test one piece. I will change standard 3/8 T fitting to accept 1/4 connection. My booster tube is for 3/8in adapter.
Hi everyone, and JackBauer...
Can anyone please post here where to get the fancy VCM casing with multiple AMP connectors front header?
I would like to know which case to use for Leaf VCM and with which connector header.
Also which wire connectors go with the header?
I cant seem to find any reference to that.
Maybe i am just not looking hard enough...
tnx
Arber
tnx
Arber
Cinch enclosures : https://www.mouser.co.uk/new/cinch/cinch-modice/
TE Deutsch enclosures : https://www.te.com/usa-en/products/conn ... =pgp-story
OK, i think i am close. On Leaf board i see 20pin and 12pin header. I see one header that i can fit, maybe.tom91 wrote: ↑Tue Aug 04, 2020 6:50 pm Cinch enclosures : https://www.mouser.co.uk/new/cinch/cinch-modice/
I found this header: https://www.newark.com/cinch-connectivi ... p/12AC5392
And this enclosure: https://www.newark.com/cinch-connectivi ... dp/53W2507
Would that be the one for Leav VCU, or Chademo VCU?
- Been thanked: 87 times
Just look at the boms on the Leaf and Gs450h github repos.
- Kevin Sharpe
- Been thanked: 4 times
I couldn't find anything and decided not to wait any longerHank wrote: ↑Thu Jun 04, 2020 6:24 pm I'm not super happy with the stock HV cables for the LDU from Tesla, and am considering building my own bespoke cables, but there are some bit's I don't know how to source, or even what they are called. They are the connectors/Shielding terminators in the attached photos.
viewtopic.php?f=11&t=37&p=15806#p15806
- Kevin Sharpe
We had the Tesla Model S/X contactors on the bench this week. I can confirm they consume ~2.5A @ 13V and get very hot. They require an economizer.Kevin Sharpe wrote: ↑Fri May 22, 2020 6:32 pmIf you run a contactor that requires an economizer without one then you'll burn out the coil.
- Has thanked: 49 times
- Been thanked: 10 times
So to test if you need economiser on random contactor, just run it for a while on the table and check if its hot?
And check amps.
Is it that easy?
And check amps.
Is it that easy?
Any contactor drawing anything more then 1 amp usually will run hot, so thats the first tale tell sign.
Went ahead and tested Ford Focus Electric 23kWh contactors.
Main HVBAT+ TE 2098952-2
It Will disconnect at 1.2V0.3A
Reconnect happens at 6.6V1.56A
Draws 2.7amps at 11v stepping down from 12V el-cheapo.
When adjusting the voltage down to point where current is 1A, it will take 4.2v
Charge/precharge contactors TE 2138551-3 draw
0,7A@12V
0,35A@6V
Cutoff 0,16A@2.8V
Cutin 0,28A@4.8V
Measured with a DIY adjustable 1-12V power supply made with about second cheapest semi ready parts on ebay, so not the most accurate but still wanted to share.
- Cookie6000
- Been thanked: 32 times
I had this in my thread but I thought I would add it in here to the Hardware thread. DC/DC converter I am using is the TDK unit from the AZD Transit Connect conversions. I gathered a lot of the info from various locations including from lars rengersen who fitted one to his Amazon.
Pin 1 is to disable. Pulling the enable pin to ground, turns off the power supply. Good direction from Lars here was to enable Pin 1 only after precharge is complete as you want the precharge energy to go do the inverter capacitors and nothing else. I actually tried this out inadvertently earlier and sure enough, the main connector wont close if the DC/DC is operating.
Pin 3 controls the output voltage. Not connected it is 14.5v. Pulled to ground is 13.8v.
Pin 6 is a fault pin. Not connected and have not found anyone who uses it yet.
The connector can be found on Alibaba - 90980-11658 10 hole Transmission solenoid valve plug for TOYOTA
http://www.kinkong-connector.com/produc ... ID898.html More info here on the unit.
https://www.diyelectriccar.com/threads/ ... ter.91682/
100A water cooled (I did read somewhere that it was 80A if air cooled, tbc).The control pins:Pin 1 is to disable. Pulling the enable pin to ground, turns off the power supply. Good direction from Lars here was to enable Pin 1 only after precharge is complete as you want the precharge energy to go do the inverter capacitors and nothing else. I actually tried this out inadvertently earlier and sure enough, the main connector wont close if the DC/DC is operating.
- Has thanked: 44 times
Hey looks like a good DC-DC option just wondering if there was a part number to google/search for?
- jcwright45
Anyone have any recommendations for water based cabin heaters besides the Nissan Leaf version? I don't want to rip out my dashboard to install a matrix unit if I don't have to. Looking for something already hacked, tested, and possibly on the inexpensive side.
- bobby_come_lately
- Has thanked: 37 times
- Been thanked: 39 times
Can't offer you tested but I am worked on modifying a cheap engine pre-heater from AC to DC. Notionally 2kw. Like this one, but only cost me about £20-25 (Chinese site I think - Aliexpress maybe?) https://www.ebay.co.uk/itm/2kw-Engine-C ... 1955251248.jcwright45 wrote: ↑Sat Sep 19, 2020 5:28 pm Anyone have any recommendations for water based cabin heaters besides the Nissan Leaf version? I don't want to rip out my dashboard to install a matrix unit if I don't have to. Looking for something already hacked, tested, and possibly on the inexpensive side.
Has 19mm barbs. Opened it up and disconnected the motor then removed the rotor and impeller and filled the gap with high temperature silicone. Planning to use it with one of the cheap VAG-clone pumps as a test.
- Cookie6000
Ah, sorry. I forgot to add in the vital piece. the TDK 9M68 14B227 AB. Here is the label
Getting close now, we have some samples made. However finding the right grounding springs and gland items is proving a bit of a pain. So probably ending up making everything bespoke.
- mdrobnak
- Been thanked: 5 times
TDK - Not exactly making cassette tapes any more! Wow. Definitely an unexpected branch name to see.Cookie6000 wrote: ↑Fri Sep 25, 2020 8:04 amAh, sorry. I forgot to add in the vital piece. the TDK 9M68 14B227 AB. Here is the label
Ya, TDK be making a lot of electronics, it is just diversified so you dont exactly know which division works on that . Even Volt gen1 DCDC is made by them.
- DarkwingDuck
I just bought the ford escape hybrid version, 8M68 14B227 AB, supposedly rated for 210-397V HVDC and with 1,5 kW max output(?). I'll try it out later and report the results hereCookie6000 wrote: ↑Fri Sep 25, 2020 8:04 amAh, sorry. I forgot to add in the vital piece. the TDK 9M68 14B227 AB. Here is the label
