Regen on braking
Has thanked: 75 times
Been thanked: 304 times
Regen on braking
Struggling to get regen working when I brake, potnom doesn't seem to drop below 0 and I don't feel any change. Ideally, I want it only when braking, so that I can lightly touch the pedal for regen down hills and just lift off to coast.
din_brake goes high with the brake pedal. I've got:
"brknompedal": -30,
  "regenramp": 10,
  "brknom": 0,
  "brkmax": -10,
  "brkcruise": -30,
  "brkrampstr": 15,
  "brkout": -50,
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Peter
Been thanked: 8 times
Re: Regen on braking
Post by Peter »
Hi Bigpie. I guess you mean potnom2 ? I will check my settings and reply as I had initial difficulty. Peter
Peter
Post by Peter »
Hi Bigpie. My settings....
throtmin -100
idcmin -100
pot2min 0
pot2max 4095
potmode SingleRegen
brknompedal -60
regenramp 50
brknom 0
brkmax 0
brkrampstr 100
brkout -100
Thanks, I'm using a can throttle, so maybe that's my issue. I'll have to faff with it some more.
VW Beetle 2003
Outlander charger
Chademo Charging
Peter
Post by Peter »
Ah, good luck and hope hope you crack the issue ASAP.
Peter
Post by Peter »
Just thinking.. Are you using brake ON signal and a manual pot for regen ?
Got this sorted now, was missing a value for pot2, now using the brake pressure value from canbus but I need to tweak around now it's working. The brake pressure value range is quite low, 120 - 255 so getting poor results at slow speeds coming to a stop.
VW Beetle 2003
Outlander charger
Chademo Charging
Has thanked: 157 times
Been thanked: 1019 times
Bigpie wrote: Thu Sep 23, 2021 8:30 am Got this sorted now, was missing a value for pot2, now using the brake pressure value from canbus but I need to tweak around now it's working. The brake pressure value range is quite low, 120 - 255 so getting poor results at slow speeds coming to a stop.
Yes same here (obviously because VAG car). I think I just use the range up till 180 or so because after that you're quite hard on the brakes already. If you configure pot2max below 255 anything above pot2max will result in the maximum programmed regen
It's more the coming to stop, when moving slowly, the regen was hammering on and off quickly. I think I need to disable regen below a certain speed/
VW Beetle 2003
Outlander charger
Chademo Charging
