Inverter Firmware v4.87.R
damian.lo
Re: Inverter Firmware v4.87.R
Post by damian.lo »
Later, when I will back to home I will send parameters from old and new firmware to comparision. It can be like this, that after upgrade some parameters are by default off?
From another thread - my BMW 116 is officially approved and I have already green plates so thank You and all of guys for support :) more info in my project.
fransoa
Post by fransoa »
I'm having a similar problem. I went from the 4.57 version to the 4.87 on a Tesla LDU and I have the same problem: no more regen. I checked all the settings: everything seems normal and the update has retained the initial values. Back to version 4.85 with "flim = 0.3": no regen, back to version 4.76: erroneous inverter temperature! I'm stuck. Unless a return to version 4.57 ?
jon volk
Post by jon volk »
I’m on 4.85 and don’t have any regen issues. Mine is driven off a brake pressure transducer so I can’t comment on throttle off regen.
Has thanked: 157 times
Been thanked: 1005 times
Would be good if you post your parameter files and a screenshot of spot values while in Run mode (I should really add a facility to post spot values as well)
fransoa
Post by fransoa »
These are my settings. New tests: same result. potnom is always >= 0.
I handed the 4.57 version to get some regen
"boost": 1850,
"fweak": 258,
"fconst": 450,
"udcnom": 350,
"fslipmin": 1.31,
"fslipmax": 3.03,
"fslipconstmax": 9,
"polepairs": 2,
"respolepairs": 1,
"encmode": 1,
"fmax": 500,
"numimp": 36,
"dirchrpm": 300,
"dirmode": 1,
"snsm": 12,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": -2500,
"il1gain": -1,
"il2gain": -1,
"udcgain": 7.5,
"udcofs": 0,
"udclim": 400,
"snshs": 0,
"bmslimhigh": 100,
"bmslimlow": -20,
"udcmin": 300,
"udcmax": 400,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 85,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"iacmax": 5000,
"ifltrise": 10,
"ifltfall": 3,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 50,
"potmax": 4095,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 5,
"throtramprpm": 20000,
"ampmin": 0.34,
"slipstart": 50,
"brknompedal": -25,
"regenramp": 5,
"brknom": 30,
"brkmax": -25,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -50,
"idlespeed": 150,
"idlethrotlim": 50,
"idlemode": 1,
"speedkp": 0.37,
"speedflt": 7,
"cruisemode": 1,
"udcsw": 0,
"udcswbuck": 0,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 0,
"canperiod": 0,
"fslipspnt": 0.84,
"ampnom": 0.34,
"version": 4,
"hwver": 3,
"opmode": 0,
"lasterr": 0,
"status": 256,
"udc": 5.31,
"idc": 0.12,
"il1": -3,
"il2": 3,
"ilmax": 3,
"uac": 0.12,
"il1rms": 3.96,
"il2rms": 4.93,
"boostcalc": 59200,
"fweakcalc": 8.06,
"fstat": 0.84,
"speed": 0,
"cruisespeed": -1,
"turns": 34,
"amp": 1704,
"angle": 24.62,
"pot": 19,
"pot2": 21,
"potnom": 0,
"dir": 0,
"tmphs": 28.75,
"tmpm": 34.53,
"uaux": 16.43,
"pwmio": 1536,
"canio": 0,
"din_cruise": 0,
"din_start": 0,
"din_brake": 0,
"din_mprot": 1,
"din_forward": 0,
"din_reverse": 0,
"din_emcystop": 1,
"din_ocur": 1,
"din_desat": 1,
"din_bms": 0,
"cpuload": 1.09
udc is near zero, can you repeat with inverter actually in RUN mode?
Otherwise I don't see anything unusual just yet
EDIT: two things I spotted:
idclim is very low at 400V and might cause unwanted overvoltage trips
I don't see forward or reverse selected
fransoa
Post by fransoa »
Hi, these parameters are saved on road : throttle up, in waiting from regen.
"boost": 1850,
"fweak": 258,
"fconst": 450,
"udcnom": 350,
"fslipmin": 1.31,
"fslipmax": 3.03,
"fslipconstmax": 9,
"polepairs": 2,
"respolepairs": 1,
"encmode": 1,
"fmax": 500,
"numimp": 36,
"dirchrpm": 300,
"dirmode": 1,
"snsm": 12,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": -5000,
"il1gain": -1,
"il2gain": -1,
"udcgain": 7.5,
"udcofs": 0,
"udclim": 400,
"snshs": 0,
"bmslimhigh": 100,
"bmslimlow": -20,
"udcmin": 300,
"udcmax": 400,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 85,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -50,
"iacmax": 5000,
"ifltrise": 10,
"ifltfall": 3,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 50,
"potmax": 4095,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 5,
"ampmin": 0.34,
"slipstart": 50,
"brknompedal": -40,
"regenramp": 5,
"brknom": 30,
"brkmax": -40,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -50,
"idlespeed": 150,
"idlethrotlim": 50,
"idlemode": 1,
"speedkp": 0.37,
"speedflt": 7,
"cruisemode": 1,
"udcsw": 0,
"udcswbuck": 0,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 0,
"canperiod": 0,
"fslipspnt": -1.31,
"ampnom": 0,
"version": 4,
"hwver": 3,
"opmode": 1,
"lasterr": 0,
"status": 0,
"udc": 383.59,
"idc": 0,
"il1": 3,
"il2": 1,
"ilmax": 5,
"uac": 0,
"il1rms": 6.96,
"il2rms": 5.37,
"boostcalc": 1691.4,
"fweakcalc": 282.18,
"fstat": 22.25,
"speed": 706,
"cruisespeed": -1,
"turns": 141,
"amp": 0,
"angle": 73.43,
"pot": 18,
"pot2": 20,
"potnom": -0.03,
"dir": 1,
"tmphs": 31.87,
"tmpm": 40.62,
"uaux": 16.43,
"pwmio": 1024,
"canio": 0,
"din_cruise": 0,
"din_start": 0,
"din_brake": 0,
"din_mprot": 1,
"din_forward": 1,
"din_reverse": 0,
"din_emcystop": 1,
"din_ocur": 1,
"din_desat": 1,
"din_bms": 0,
"cpuload": 25.09
Can you temporarily disable the idle speed controller?
fransoa
Post by fransoa »
I tried this without a good result just by putting idlespeed=0
I'm going to do the test again as soon as I'm at the workshop by putting idlemode=3.
For information: if I have my foot on the brake (din_brake=1) there is no regen either.
fransoa
Post by fransoa »
Hi, test done: idlemode=3 and idlespeed=0. Still no regen
fransoa
Post by fransoa »
Ok, more debugging needed.
I have attached a firmware that will display the various values of potnom as it trickles through the processing pipeline. Can you get to the state where it should regen, but doesn't and then post the values of potnom1...7 and potnom?
stm32_sine.zip
(27.42 KiB) Downloaded 81 times
fransoa
Post by fransoa »
I'm doing the test quickly.
I recently encountered on a vehicle that worked well the following problem: quite often I can not pass the inverter in START because of an overCURRENT error. it's totally random, the temperature doesn't do anything and I can't find the cause. I searched the source code for the causes of this error when the engine is shutdown and no current is consumed. If you have a idea... this noon the vehicle is stopped on this error
fransoa wrote: Tue Aug 18, 2020 10:48 am I'm doing the test quickly.
Gate driver errors also report as OVERCURRENT, I reckon it's that
fransoa
Post by fransoa »
Do you think the problem is the inverter, the electronic card or the wiring? If the inverter starts, the vehicle works very well as long as you don't stop the inverter. It is impossible to determine the result of the START, if it fail, we wait a few minutes or few hours and it works again. I controlled the internal temperatures and electronic card temperatures: everything seems okay. Now I can not do the test of your version because START does not pass ...
fransoa
Post by fransoa »
We are lucky for this time, i have the data brake and throttle pedals up :
"boost": 1850,
"fweak": 258,
"fconst": 450,
"udcnom": 350,
"fslipmin": 1.31,
"fslipmax": 3.03,
"fslipconstmax": 9,
"polepairs": 2,
"respolepairs": 1,
"encmode": 1,
"fmax": 500,
"numimp": 36,
"dirchrpm": 300,
"dirmode": 1,
"snsm": 12,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": -5000,
"il1gain": -1,
"il2gain": -1,
"udcgain": 7.5,
"udcofs": 0,
"udclim": 450,
"snshs": 0,
"bmslimhigh": 100,
"bmslimlow": -20,
"udcmin": 300,
"udcmax": 400,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 85,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -50,
"iacmax": 5000,
"ifltrise": 10,
"ifltfall": 3,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 50,
"potmax": 4095,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 5,
"ampmin": 0.34,
"slipstart": 50,
"brknompedal": -40,
"regenramp": 5,
"brknom": 30,
"brkmax": -40,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -50,
"idlespeed": 150,
"idlethrotlim": 50,
"idlemode": 1,
"speedkp": 0.37,
"speedflt": 7,
"cruisemode": 1,
"udcsw": 0,
"udcswbuck": 0,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 0,
"canperiod": 0,
"fslipspnt": -1.31,
"ampnom": 0,
"version": 4,
"hwver": 3,
"opmode": 1,
"lasterr": 0,
"status": 0,
"udc": 385.31,
"idc": 0,
"il1": -2,
"il2": 1,
"ilmax": 1,
"uac": 0,
"il1rms": 6,
"il2rms": 6.03,
"fstat": 20.87,
"speed": 750,
"cruisespeed": -1,
"turns": 1971,
"amp": 0,
"angle": 176.09,
"pot": 19,
"pot2": 21,
"potnom": -0.03,
"potnom1": -0.03,
"potnom2": -0.03,
"potnom3": -0.03,
"potnom4": -0.03,
"potnom5": -0.03,
"potnom6": -0.03,
"potnom7": -0.03,
"dir": 1,
"tmphs": 28.12,
"tmpm": 28.9,
"uaux": 16.43,
"pwmio": 0,
"canio": 0,
"din_cruise": 0,
"din_start": 0,
"din_brake": 0,
"din_mprot": 1,
"din_forward": 1,
"din_reverse": 0,
"din_emcystop": 1,
"din_ocur": 1,
"din_desat": 1,
"din_bms": 0,
"cpuload": 24.87
fransoa
Post by fransoa »
The same with brake down:
"boost": 1850,
"fweak": 258,
"fconst": 450,
"udcnom": 350,
"fslipmin": 1.31,
"fslipmax": 3.03,
"fslipconstmax": 9,
"polepairs": 2,
"respolepairs": 1,
"encmode": 1,
"fmax": 500,
"numimp": 36,
"dirchrpm": 300,
"dirmode": 1,
"snsm": 12,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": -5000,
"il1gain": -1,
"il2gain": -1,
"udcgain": 7.5,
"udcofs": 0,
"udclim": 450,
"snshs": 0,
"bmslimhigh": 100,
"bmslimlow": -20,
"udcmin": 300,
"udcmax": 400,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 85,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -50,
"iacmax": 5000,
"ifltrise": 10,
"ifltfall": 3,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 50,
"potmax": 4095,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 5,
"ampmin": 0.34,
"slipstart": 50,
"brknompedal": -40,
"regenramp": 5,
"brknom": 30,
"brkmax": -40,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -50,
"idlespeed": 150,
"idlethrotlim": 50,
"idlemode": 1,
"speedkp": 0.37,
"speedflt": 7,
"cruisemode": 1,
"udcsw": 0,
"udcswbuck": 0,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 0,
"canperiod": 0,
"fslipspnt": -1.31,
"ampnom": 0.03,
"version": 4,
"hwver": 3,
"opmode": 1,
"lasterr": 0,
"status": 0,
"udc": 385.18,
"idc": 0,
"il1": -4,
"il2": 4,
"ilmax": 4.5,
"uac": 0,
"il1rms": 5.03,
"il2rms": 4.46,
"fstat": 54.18,
"speed": 1665,
"cruisespeed": -1,
"turns": 2545,
"amp": 2,
"angle": 149.87,
"pot": 19,
"pot2": 21,
"potnom": -0.03,
"potnom1": -0.03,
"potnom2": -0.03,
"potnom3": -0.03,
"potnom4": -0.03,
"potnom5": -0.03,
"potnom6": -0.03,
"potnom7": -0.03,
"dir": 1,
"tmphs": 28.75,
"tmpm": 30.46,
"uaux": 16.43,
"pwmio": 0,
"canio": 0,
"din_cruise": 0,
"din_start": 0,
"din_brake": 1,
"din_mprot": 1,
"din_forward": 1,
"din_reverse": 0,
"din_emcystop": 1,
"din_ocur": 1,
"din_desat": 1,
"din_bms": 0,
"cpuload": 24.87
Thanks. Very strange, will check.
Isaac96
Post by Isaac96 »
Try idlespeed = -100
fransoa
Post by fransoa »
With idlespeed=-100
"boost": 1850,
"fweak": 258,
"fconst": 450,
"udcnom": 350,
"fslipmin": 1.28,
"fslipmax": 3,
"fslipconstmax": 9,
"polepairs": 2,
"respolepairs": 1,
"encmode": 1,
"fmax": 500,
"numimp": 36,
"dirchrpm": 300,
"dirmode": 1,
"snsm": 12,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": -2500,
"il1gain": -1,
"il2gain": -1,
"udcgain": 7.5,
"udcofs": 0,
"udclim": 450,
"snshs": 0,
"bmslimhigh": 100,
"bmslimlow": -20,
"udcmin": 300,
"udcmax": 400,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 85,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"iacmax": 5000,
"ifltrise": 10,
"ifltfall": 3,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 100,
"potmax": 4095,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 5,
"ampmin": 0.31,
"slipstart": 50,
"brknompedal": -40,
"regenramp": 5,
"brknom": 30,
"brkmax": -40,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -50,
"idlespeed": -100,
"idlethrotlim": 50,
"idlemode": 3,
"speedkp": 0.34,
"speedflt": 7,
"cruisemode": 1,
"udcsw": 0,
"udcswbuck": 0,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 0,
"canperiod": 0,
"fslipspnt": -1.28,
"ampnom": 0.03,
"version": 4,
"hwver": 3,
"opmode": 1,
"lasterr": 0,
"status": 0,
"udc": 385.06,
"idc": 0,
"il1": -1,
"il2": 3,
"ilmax": 2.75,
"uac": 0,
"il1rms": 4.59,
"il2rms": 8.56,
"fstat": 65.34,
"speed": 2040,
"cruisespeed": -1,
"turns": 762,
"amp": 3,
"angle": 158.31,
"pot": 19,
"pot2": 21,
"potnom": -0.03,
"potnom1": -0.03,
"potnom2": -0.03,
"potnom3": -0.03,
"potnom4": -0.03,
"potnom5": -0.03,
"potnom6": -0.03,
"potnom7": -0.03,
"dir": 1,
"tmphs": 27.18,
"tmpm": 29.53,
"uaux": 16.43,
"pwmio": 0,
"canio": 0,
"din_cruise": 0,
"din_start": 0,
"din_brake": 0,
"din_mprot": 1,
"din_forward": 1,
"din_reverse": 0,
"din_emcystop": 1,
"din_ocur": 1,
"din_desat": 1,
"din_bms": 0,
"cpuload": 24.87
Can you set potmin to 0?
What the above test resulted in is that the UserThrottleCommand is already 0. The the 0 isn't caused by derating or idle speed.
fransoa
Post by fransoa »
potmin 100 -> 0 : exacly the same problem. potnom1..7 = 0.00
Think I found it now. Can you set pot2min=1 and pot2max=10
fransoa
Post by fransoa »
Thank you very much. The test is conclusive. The regen works with these parameters. idlespeed management works. It's an all-terrain vehicle and the idlespeed, brkmax and brknompedal settings are managed by the driver and transmitted by CAN bus.
If anyone has an idea also for my OVERCURRENT error problem when I put the START to ON. (see below in this topic)
Today I replace the electronic card without understanding what's going on.
Great :) Will be fixed in the next release.
Try lowering idlethrotlim or alternatively slowly ramping idlespeed
