I am building an EV with the above items and using them in conjunction with Chevy Bolt battery pack and Tesla drivetrain. Does anyone have a contact that can make the Bolt components work in this build?
Reverse-engineering Chevy Bolt BMS/ Charger/ DC-DC 14v
- Kevin Sharpe
- Been thanked: 4 times
Re: Reverse-engineering Chevy Bolt BMS/ Charger/ DC-DC 14v
What's your budget for this development?TheLifeHacker wrote: ↑Thu Mar 28, 2019 10:41 amDoes anyone have a contact that can make the Bolt components work in this build?
- Has thanked: 80 times
- Been thanked: 232 times
See if you can use CAN MSG from Volt components?TheLifeHacker wrote: ↑Thu Mar 28, 2019 10:41 am I am building an EV with the above items and using them in conjunction with Chevy Bolt battery pack and Tesla drivetrain. Does anyone have a contact that can make the Bolt components work in this build?
https://leafdriveblog.wordpress.com/201 ... dc-or-apu/
https://leafdriveblog.wordpress.com/201 ... a-charger/
https://leafdriveblog.wordpress.com/201 ... ic-heater/
https://leafdriveblog.wordpress.com/201 ... -and-fans/
Hi, I’m doing EV convention based on Tesla big drive unit and Chevy Bolt batteries. I have in my shop complete car Chevy bolt (damaged a little but I can make it run) if you need any support - let me know ))
I can scan and record can-bus signals or what ever you may need
Also I have Chevy bolt wiring diagram
- Boxster EV
- Has thanked: 35 times
- Been thanked: 26 times
Speak to tom91 (Tom De bree). He can provide you with a virtually out of the box, cost effective solution for the Chevy kit.
He has done the Chevy Volt, not Bolt.Boxster EV wrote: ↑Thu Feb 27, 2020 2:03 pm Speak to tom91 (Tom De bree). He can provide you with a virtually out of the box, cost effective solution for the Chevy kit.
Although it is worth checking if they reused the same CAN commands.
- Has thanked: 102 times
- Been thanked: 216 times
I believe with the Bolt and Volt gen 2 they went a step back, alot of the controls are pwm/analogue signals so you require a working vehicle to reverse engineer.
If anyone is based in the UK I could potential help out, at some form of compensation.
