VW Mild Hybrid Starter Alternator
- Has thanked: 49 times
- Been thanked: 10 times
Re: VW Mild Hybrid Starter Alternator
Wonder how "someone" allways tells you and others interested in EV conversion that it cannot be done DIY style..
- Has thanked: 268 times
- Been thanked: 149 times
Would something like this work with one of these motors?
https://www.evcomponents.com/keb72100x- ... oller.html
I'd love to build an electric lawn tractor and 10kw would be more than enough.
I need a bigger hammer!
Propably to some extent, just like your e-bike/leaf/rover, but since the motor allready has the ESC/inverter parts built-in, it would be best to get it spinning as-is woth CAN control.
WOTS SO FUNNY!!
My 1hp Land Rover is great.
This is even better if it don't need more filthy lucre spent on it.
I guess I missed the important part of this thread.
- EV_Builder
- Has thanked: 16 times
- Been thanked: 33 times
Ok, i dived into this, but can you elaborate on the sense of this? As a starter it will just be on or off. Are you sure it will be speed controlled?
I know some handy guys who make it speed controlled with our own firmware
As for the checksum stuff you could buy the CPU (and pray you get it to talk what you need) or we can try to find other canbus logs and simply replay them into the motor and see what it does or doesn't. Do you know if the motor in the VAG is connected to the gateway by canbus? Or does it has its own bus with the engine control unit?
- mjc506
- Has thanked: 30 times
- Been thanked: 28 times
Not just a starter, it can start the ICE, but can also provide additional torque, and can take torque (regen) on braking/cruise/whatever - it should accept some form of torque/speed/current/power command over the interface.
Finding a CANbus log including start/run/stop would be great...
- Been thanked: 4 times
I saw where you asked if anyone could crack the CRC. I tried, it's hard. It appears that message 0x1AC probably implements the same CRC calculation so I tried to figure out what they did. Unfortunately, it's not being cooperative. I don't yet know how they calculated that CRC byte.Jack Bauer wrote: ↑Thu Mar 25, 2021 2:35 pm So we just told it the ignition is on and it wakes and starts sending us messages. Now problem is I'm not firing off the counter and checksum so it don't like me.
Source :
https://github.com/commaai/opendbc/blob ... b_2010.dbc
So, this message is pointless. The only reason I sent it was to say that I did try. These things can take quite a bit of effort to crack sometimes. It would sure help if someone had firmware for this device. Alternatively, good captures from a working car would also be handy. But, the capture you have seems to have enough data in 0x1AC to be good enough for testing and cracking. I just failed so far. It looks like it should be a CRC8 algorithm but none seem to work. Sometimes I can get some chunks to work but then other messages fail. So, I might be close. Sometimes you've go to do weird things like include the CAN ID in the CRC calc or add up the bytes then do CRC, the options are nearly endless. Only one option is likely to work so it's like standing in a swimming pool of rice and trying to find the brown one.
- Been thanked: 87 times
Much appreciated Colin. I'm on the lookout for a suitable car to grab some can logs. Until then this project like so many is on hold ...
- EV_Builder
@Jack aka Damien; let me know when you need this then i dive into this CRC calculation.
I'm now doing the porsche ones...so far so good
Hey guys Im new to the group Any updates on this unit thinking of using one on my hybrid swap porsche i found some on ebay for cheap I do have some can experience Did anyone make more headway
- EV_Builder
Did you succeed in this?Jack Bauer wrote: ↑Thu May 13, 2021 11:31 am Much appreciated Colin. I'm on the lookout for a suitable car to grab some can logs. Until then this project like so many is on hold ...
Hey Damien
Haven't tested, but looks to be XOR
XOR the First half of the CAN ID with the Last Half then continue XOR
CRC = 3 ^ C0
CRC = CRC ^ Byte 3
CRC = CRC ^ Byte 2
CRC = CRC ^ Byte 1
Byte 0 = CRC
Would be interested if it works
CRC = 3 ^ C0
CRC = CRC ^ Byte 3
CRC = CRC ^ Byte 2
CRC = CRC ^ Byte 1
Byte 0 = CRC
Jack Bauer wrote: ↑Thu Mar 25, 2021 2:35 pm What appeals to me about this is the all in one aspect.
Some progress. Seems 0x3c0 byte2 bit 1 is KL15 via can :So we just told it the ignition is on and it wakes and starts sending us messages. Now problem is I'm not firing off the counter and checksum so it don't like me.Code: Select all
BO_ 960 Klemmen_Status_01: 4 Gateway_MQB SG_ Klemmen_Status_01_CRC : 0|8@1+ (1,0) [0|255] "" Airbag_MQB,BMS_MQB,Motor_Diesel_MQB,Motor_Hybrid_MQB,Motor_Otto_MQB SG_ Klemmen_Status_01_BZ : 8|4@1+ (1,0) [0|15] "" Airbag_MQB,BMS_MQB,Motor_Diesel_MQB,Motor_Hybrid_MQB,Motor_Otto_MQB SG_ ZAS_Kl_S : 16|1@1+ (1,0) [0|1] "" Vector__XXX SG_ ZAS_Kl_15 : 17|1@1+ (1,0) [0|1] "" Airbag_MQB,BMS_MQB,Motor_Diesel_MQB,Motor_Hybrid_MQB,Motor_Otto_MQB SG_ ZAS_Kl_X : 18|1@1+ (1,0) [0|1] "" Vector__XXX SG_ ZAS_Kl_50 : 19|1@1+ (1,0) [0|1] "" Vector__XXX
Source :
- EV_Builder
It's not a XOR atleast I'm quite sure.
After playing and trying i come to the conclusion that a XOR would mean that if one byte changes the checksum result will also change with that amount. And that's not the case. Also a XOR can mean same CRC but different message.
I can also share that it's not a standard Polynom or that CRC needs tobe mirrored etc.
I keep searching in my spare spare spare time
Works for my dataset
CC 08 07 00
CF 0B 07 00
C8 0C 07 00
CA 0E 07 00
- EV_Builder
I was referring to 1A0 and 1AC....
A look inside!
Didn't mind hot-linking since they're on a 3rd party hosting site.
Link below is from a Russian Ukrainian forum, seems they're working on it as well.
**Apologies for the Russian/Ukrainian mixup, as pointed out by jnsaff. The Domain is indeed an Ukraine forum. I was a bit too quick to write the post. **
Source:
https://electroavtosam.com.ua/forums/vi ... 2&start=15
Source:
- EV_Builder
Wel johu/damien thats an ST chip!
- Bratitude
- Has thanked: 57 times
- Been thanked: 173 times
Ooh boy, very cool. line/signal tracing would be model 3 all over again. But Dayum after that, it be nice and easy for hybrid conversions
- Has thanked: 157 times
- Been thanked: 1018 times
Did they add their own encoder?
Would be fun to do a replacement board for it. Good old plain OI gate drive.
I wonder about the specs of the switches. IGBT? FET?
edited... see below
edited... see below
- jnsaff
- Has thanked: 2 times
- Been thanked: 8 times
Just a sidenote .ua is Ukrainian domain, not to say the people on there could not be Russian and that they don't write Russian there but some people might find it offensive when you get lumped together with a different country that just so happens is preparing to invade yours.
- Has thanked: 75 times
- Been thanked: 304 times
Does this help with the CRC? https://github.com/commaai/opendbc/blob ... mon.cc#L95
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
- EV_Builder
I think it isn't the one for the 1AC / 1A0 's but will check when I come around this again.Bigpie wrote: ↑Sun Feb 20, 2022 9:08 pm Does this help with the CRC? https://github.com/commaai/opendbc/blob ... mon.cc#L95
Hi there,
Sorry to dig this thread back up again, but as I'm about to start down much the same road
(attempting to get an Valeo iBSG to function using it's integrated controller)
I thought I'd check a few questions;
Has anyone tried contacting Valeo, on the (unlikely) off chance they'll supply the communication protocol?
I've been looking into snippets of code on github from other projects attempting to control previous valeo alternators (not ones that can drive)
and those projects centred about the LIN bus pin. Could it be CAN is for monitoring and LIN is for control?
- EV_Builder
Everything is possible there are no limits to suchs things but if you ask me it wouldn't make sense. If the control systems wants fast control over the motor/generator then CanBus is a must. LIN is cheaper tough so there you go.
I got a reply from Valeo (which was a pleasant surprise) but unfortunately they couldn't give me any of the technical information we'd need.
So frustrating as getting control of these units would make them perfect, small, cheap and easy!
