EVO AF130 Axial Flux motor - easy to drive? Topic is solved
JamesWLG
Post by JamesWLG »
Hi all,
In a recent web surfing procrastination I came across these motors
https://turntide.com/learning/evo-axial ... tor-af130/
If I got carried away with my credit card and bought one is it going to be hard to find and set up an inverter to drive it (assuming I don't buy one from the same firm with it)?
Ideally I'd like to have the option to use the open inverter board with a salvage inverter to keep cost down in some areas at least.
Been thanked: 960 times
Re: EVO AF130 Axial Flux motor - easy to drive?
I've driven an axial flux motor with open inverter in the past. Nominal power at 600V would require 300A phase amps, so even a humble Prius inverter would at least get you started.
