Main Board Version 3+Prius Gen2(32 pin)? Topic is solved
Good afternoon! Dear engineers, who can help, schematically show the correct connection of the main board 3 Johannes for the Gen2 inverter. I would like to make sure that my connection is reliable and correct, in order to avoid magic smoke). And maybe there are working settings for the MG lexus rx 400-450h?
- Has thanked: 157 times
- Been thanked: 1018 times
Re: Main Board Version 3+Prius Gen2(32 pin)?
Look here: https://openinverter.org/wiki/Toyota_Pr ... ed_pinouts
And here: https://openinverter.org/parameters/ (and bug someone with that combination to post parameters )
Thank you Johannes, the installation parameters are very useful for setting up! I spent a lot of time in the wiki, learning terms and schemes, for which a special thank you to the people who spent a lot of effort on creating a wiki, this is amazing information for alternative enthusiasts. Only due to the inaccuracy of the translation of the notation, there are doubts that my connections Rev3 and Gen2 are correct, I have not yet found a graphical illustration of the connection output/input for Rev3 and Gen2. I'll keep looking and try not to burn anything)
