Jag X Type Estate conversion
Hi all, complete beginner looking to see if this is even feasible? What sort of motor I'd need to make it work well. Looking to be able to get 150-200 miles in a charge. Wanting AC so I can have regen braking.
Re: Jag X Type Estate conversion
I'm only new to this forum but I just thought I'd follow up and see if you've been able to progress this? Check out ArturK's youtube channel: https://www.youtube.com/channel/UCYdTog ... lZSiBHDEMw. He's on here and may be useful.
Sounds like you need to do a little more research about motors, batteries and ancillaries. It's a rabbit hole but the more you read you really do get a better idea of what suits your build very quickly.
The GS450h solution is good for rear wheel drive cars, that's what I'm going with.
