Good evening,
Can I use any charger with Tesla batteries, or must I use a Tesla charger (and then install the opensource controller)?
Haven't been able to find the answer elsewhere and I don't want to waste a lot of money on buying a charger which may not work.
If I can use any charger, could you please send me some recommendations?
Jon
Any charger with Tesla batteries? Topic is solved
- Bratitude
- Has thanked: 57 times
- Been thanked: 174 times
Re: Any charger with Tesla batteries?
JonMegaTron wrote: ↑Fri Jan 22, 2021 9:51 pm Good evening,
Jon
as long as it out puts the correct voltage at a given rate, use what ever you like.
but sounds like you need to take a few steps back to understand what you are trying to do.
working with some potentially very dangerous components
Thanks for the answer!
I'm still a long way from even buying the parts, but I just wanted to start planning.
