BMW i3 11kW KLE onboard charger multi-phase
FJ3422
Post by FJ3422 »
Looking for a lighter alternative for the bulky Tesla 11kW on-board charger, I came across the i3 charger.
- Half the weight
- CCS Fast-charge contactors integrated
Scored one and took it apart yesterday. First remarkable thing I did not know; the KLE for the 3-phase chargeable i3 is just a 2-phase charger ! Charger for the third phase seems to be integrated in the EME.
Anyone already did some reverse-engineering om this thing ? I do have access to a 2019 i3 (with exactly this KLE inside) since a couple of days, so will make some CAN-logs one of these days.
Some pictures:
Has thanked: 80 times
Been thanked: 234 times
Re: BMW i3 11kW KLE onboard charger multi-phase
FJ3422 wrote: Thu Jun 24, 2021 9:03 am Looking for a lighter alternative for the bulky Tesla 11kW on-board charger, I came across the i3 charger.
Can you take a photo of charger stickers and P/Ns in detail?
tnx
FJ3422
Post by FJ3422 »
This is the 6144 8482639 / produced in 2019.
https://www.realoem.com/bmw/enUS/showpa ... 1449845423
Been thanked: 87 times
Some CCS logs from the 2019 i3 would be very helpful also:)
You will find some logs and a dbc on my github :
https://github.com/damienmaguire/BMW-i3-CCS
FJ3422
Post by FJ3422 »
Jack Bauer wrote: Thu Jun 24, 2021 12:33 pm Some CCS logs from the 2019 i3 would be very helpful also:)
Sure, no problem ! Handling an electric car that just 'works' is new to me, so still have to arrange some charge cards, look for a quiet CCS-station around here, find a place to tap the CAN-wiring and kindly ask her not to plug the thing into the wall after every short trip so there is something to charge :-)
steveknox
Has thanked: 15 times
Post by steveknox »
Just a prod -- I'm keen on using one of these as it looks like a really neat package for CCS as well as AC charging. Have you managed to get any can logs?
opelmanta
Post by opelmanta »
Anyone done any investigation on this unit, also on non CCS AC only onboard charger.
Has thanked: 57 times
Been thanked: 176 times
I friend has a i3 now, the charger throttles to 3.3kw because of crappy cooling. BMW has recals for older revisions of Kle units. Not sure the dates, but Might be worth checking when buying second hand
FJ3422
Post by FJ3422 »
opelmanta wrote: Fri Oct 08, 2021 9:09 pm Anyone done any investigation on this unit, also on non CCS AC only onboard charger.
steveknox wrote: Thu Sep 02, 2021 9:30 pm Just a prod -- I'm keen on using one of these as it looks like a really neat package for CCS as well as AC charging. Have you managed to get any can logs?
Not yet. I hoped to find a 3-phase 11kW charger in this thing. Unfortunately it is just a 2-phase (6,6kW) charger, the third phase (3,3kW) is integrated in de EME, so the charger is less interesting for my build. Will figure CAN-control out somewhen, but it currently has no priority for me.
cloudy
Post by cloudy »
Anyone had any luck getting one of these to fire up?
