I'd be very interested to find out more about what you are doing on the vcu side.
I used to do tcu and vcu as for a major car manufacturer. I'm now working on a project for myself but need to get hold of suitable hardware.
I've had coil bobbins 3D printed with great results. The sample pack contained printed connector housings.
Great, thanks! For some reason I didn't actually think to just Google itRAS_666 wrote: ↑Tue Jun 16, 2020 12:07 am This any help?
http://mmc-manuals.ru/manuals/outlander ... dex_M1.htm
Unless it takes you to the main page click 90 circuit diagrams and them motor control systems it's got the front and rear inverters.
I have a sla 3d printer resolution on that would be good enough to make the plugs unfortunately my design skills aren't
Don't worry, that just means you're like 99.99% of the population.
I tried OnShape after running into the limitations of Designspark Mechanical (a free, but heavily cut down version of SpaceClaim).By the way, can highly recommend Onshape and following a few YouTube videos, you'd be designing parts in no time! (Honestly I'm an electrical engineer, only have a few hours of CAD experience).
iirc the last coupler we had made was 80 euro and just required the gearbox and motor at the engineering workshop for a couple of days (they also made an adapter plate at the same time). Watch from 5:00 in this video;
That's really useful to know and a good price! Will have to try some machine shops around here then. Was it a specialist in anything in particular? Damian mentioned a Drive shaft shop.Kevin Sharpe wrote: ↑Sun Jun 21, 2020 6:14 am iirc the last coupler we had made was 80 euro and just required the gearbox and motor at the engineering workshop for a couple of days (they also made an adapter plate at the same time). Watch from 5:00 in this video;
viewtopic.php?f=11&t=30#p4751
I tried a clutch plate from a Skoda Felicia 1.3 P/N 047141034 as it had the correct No of splines and matching ID / OD spline dimensions. However the spline profile is different so it won't go on the shaft. (Younger me might have hammered it on )
Do you have a part number for that Suzuki Jimny clutch plate? All the online sellers list it as having 20 splines (motor 18) but it wouldn't be the first time I've mixed and matched things only to discover there were specifications misquoted across all the websites probably all referencing the same xrefrence data.ScottS wrote: ↑Wed Jun 24, 2020 10:09 pm Turns out though, that the Suzuki Jimny clutch does appear to fit! With a very small amount of play, perhaps 1 degree (1mm at outer edge of clutch). Not sure what is an allowable amount of play on a spline shaft, but from what I could see from a sample size of 1 YouTube video, it appears a fairly normal amount.
Yep, I believe it was bought as ADK83106Mouse wrote: ↑Tue Jul 07, 2020 12:32 pm
Cool, that sounds good then, from what I could see online seemed about right. Both shafts are hardened so they're not going to wear too much!
Regards the iMiev adaptor, was the part you ordered the part number you're referring to but didn't fit the outlander motor? Was it a single piece out of the gearbox?.perhaps we can find the part in the Outlander rear diff?rstevens81 wrote: ↑Tue Jul 07, 2020 3:15 pm If the splines are the same as I-meiv, there is a coupler with the part number 2526A144
My motor (outlander) only turned up yesterday so I haven't managed to order one yet or find out how much they cost or even if you can actually buy one.
Hope this helps.
Edit found through here: https://www.online-teile.com/oem-kataloge/
https://cat.ilcats.ru/mitsubishi/?funct ... anguage=en
My local mitsubishi wouldn't tell me anything unless I have a vin!!
Edit fyi ordered one from Germany however totally different shaft DIA (so junk to me ... If anyone has imeiv motor they are welcome ut)
Any news on your Civic car? How is control of Outlander rear motor? Thanks for the update.pemtek wrote: ↑Sun Apr 12, 2020 11:51 pm I have a motor, inverter, charger and battery from an outlander installed in a Honda civic. The charger and motor only need 4 can commands between them in total to work. I have shared the information with a couple of people on here already. But I will be in a position to report actually driving a car running the outlander parts in the next few days if I can get a few hours on it away from jobs around my home..
I actually have a stack of chargers, 7 motors and inverters. I also have a front transmission which has 2 motors and the front inverter controls both motors easily with basically the same commands that drive the rear. It looks entirely possible to use both motors in parallel for a really good power output for the money.
Phil
Hi Phil,pemtek wrote: ↑Sun Apr 12, 2020 11:51 pm I have a motor, inverter, charger and battery from an outlander installed in a Honda civic. The charger and motor only need 4 can commands between them in total to work. I have shared the information with a couple of people on here already. But I will be in a position to report actually driving a car running the outlander parts in the next few days if I can get a few hours on it away from jobs around my home..
Phil
