Gen 3 inverter converter control software
celeron55
Has thanked: 28 times
Been thanked: 110 times
Re: Gen 3 inverter converter control software
Post by celeron55 »
Bigpie wrote: Thu Aug 06, 2020 6:51 am TEST_BOOST_VOLTAGE is what I added to do just that. Bucking works (not tested using your software) but not boosting, looks like I might need to dig further and spend some time to understand timers and registers.
Am I right is assuming boosting is just doing PWM on pin 9 instead of 10 or am I reading this code wrong?
Yes, it is supposed to just do PWM on the other pin. Do you have a scope or something handy to measure it directly on the atmega328 pin?
Has thanked: 75 times
Been thanked: 304 times
So as a test I've pulled the board out, set 9 and 10 at 50% duty.
Output from the pins looks good.
I've followed this to TR8 and TR9 then the R88 and R87 to the 50way connector, both the same
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
celeron55
Post by celeron55 »
That looks ok assuming the IGBT driver board is disconnected. Once connected it will supply the 5V pull-up to the lines. If it doesn't supply 5V, that means it's detecting a fault in the IGBT.
Both look good when hooked up. I'll put the inverter back together tomorrow and stuck a voltage on the DC bus and see if I get any boosting with just setting the PWM and 50%.
VW Beetle 2003
Outlander charger
Chademo Charging
I must be doing something wrong.
I've got 83v on the RHS side as in the photo. I've got a multimeter on LHS (1 & 2) an no load
|.  RHS (in).    |.    LHS (out).        |.    Pin 9 PWM.        |.    Pin 10 PWM.     |
|.    83         |         0             |            0          |          0          |
|     83         |         0             |           50%         |          0          |
|     83         |        83             |            0          |         50%         |
|     83         |        83             |            0          |         20%         |
|     83         |         0             |           20%         |          0          |
|     83         |         0             |           80%         |          0          |
I've checked BOOST_FAULT and it remains at 5v.
I've noticed a lower value for PWM results in a higher percentage PWM.
PWM = 50 gives 80%
PWM = 200 gives 20%
I must be missing something. I don't seem to be able to buck or boost
#include <Arduino.h>
#define DCBUS1_PIN               A0
#define DCBUS2_PIN               A1
#define BOOST_LOW_SWITCH_PIN      9
#define BOOST_HIGH_SWITCH_PIN    10
int PWMDuty = 0;    //pwm duty cycle
void setup() {
  Serial.begin(115200);//
  TCCR1B = TCCR1B & B11111000 | B00000010;    // set timer 1 divisor to  8 for PWM frequency of  3921.16 Hz
  pinMode(A0, INPUT); //boost Hi side
  pinMode(A1, INPUT); //boost Hi side
  analogWrite(10,0); //low side off
  PWMDuty=0;
void loop() {
PWMDuty=20;
//  analogWrite(10,PWMDuty);
analogWrite(9, PWMDuty); //low side off
delay(1500);
VW Beetle 2003
Outlander charger
Chademo Charging
Right, now I can buck from dc bus 2 down to dc bus 1. Is this thing able to buck and boost in both directions?
VW Beetle 2003
Outlander charger
Chademo Charging
johnstef
Post by johnstef »
Jack Bauer wrote: Wed Jun 17, 2020 2:13 pm
jalovick wrote: Wed Jun 17, 2020 1:22 pm I know this isn't exactly associated, but I had a thought, is it possible to use any part of the inverter/converter to add a 240V AC 50 Hz single phase output, or is that best done separately?
Working on just that....
Any progress on outputting 240v AC from the Inverter? My interest is for the USA grid, 240v AC 60 Hz. The inverter would supply AC mains current to my home from a 7kw to 10kw Li battery pack.
Been thanked: 87 times
viewtopic.php?f=14&t=969
Lets keep this thread on topic please.
So I was running the prius3charger_buck (latest version), and all was well. I had single phase connected through a lightbulb, to MG1 (1&3) it light briefly and went out. Using TEST_BUCK = true.
I turned the mains power off and when I turned it off I heard a click sound from the inverter. Now when I turn mains back on the bulb stays on. Any clues what I've done and what I've killed?
VW Beetle 2003
Outlander charger
Chademo Charging
celeron55
Post by celeron55 »
Do some continuity measurements and you'll probably find out. Definitely sounds like the converter high or low side died.
Would be be kind enough to point me to where I'd be probing? I'm not sure which legs are for the buck boost mosfets
EDIT found this: Image
I have a short between + and -, It's dead, Jim.
1/ If I cut the legs of the boost IGBTs I'm guessing that would allow me to still drive a motor with MG1/MG2?
2/ I'm assuming I've had both the high and low on at the same time? I was only running test_buck, does some dead time need bringing in to stop the happening when I get another inverter?
VW Beetle 2003
Outlander charger
Chademo Charging
A bad thing has happened. I've been in to the goo and cut away. Hopefully can still use mg2 for now.
I'll pick up another inverter at some point.
VW Beetle 2003
Outlander charger
Chademo Charging
celeron55
Post by celeron55 »
In these cases it's difficult to tell what the root cause is.
I think some of the used inverters on sale do have problems with the boost IGBTs, so there's a chance it's bad luck.
My code might just suck, altough I've personally ran it more than enough to give it a chance to destroy my IGBTs.
It could also be that some versions of the inverter have worse protection than others, and only the better ones survive the code. Who knows.
I'm not sure, it went pop when I'd turned the mains off but with no load on the dc bus, the 12v supply was still on to the inverter, using test buck. Not sure if thats anything to do with it.
I don't know much about using timers so I get lost following your code there. I did wonder why the code that appears to set deadtime isn't used?
// Sets high side switch PWM, and low side switch PWM based on it
static void set_pwm_buck_active(uint16_t highswitch_ontime)
	if(!current_sensor_zero_offsets_calibrated)
		return;
#if 0
	const float deadtime_ns = 2500;
	const uint16_t deadtime = (uint16_t)((float)deadtime_ns/(1.0/16e6*1e9));
	set_ontimes(highswitch_ontime + deadtime, highswitch_ontime);
#else
	set_ontimes(ICR1+1, highswitch_ontime);
#endif
VW Beetle 2003
Outlander charger
Chademo Charging
celeron55
Post by celeron55 »
It doesn't activate the low side IGBT at all. The low side is just used as a diode. If you change it to #if 1, then the lowside is also driven, but I didn't test that option at all because on my inverter the low side IGBT is toast. The diode works and it isn't shorted, but it can't be activated.
Note that set_ontimes() has weird parameters. The first parameter is lowside offtime and the second parameter is highside hightime. I wrote it to directly match to how the underlying timer is set up.
going to make this a sticky as it seems to have fallen off the radar and is an important development.
I've started working on a basic web interface for this so I don't have to plug in.
https://github.com/jamiejones85/PriusCh ... bInterface
So far it uses Web Sockets to display the serial output from the charger.
Plans are to allow uploading of new firmware and set configuration options at least, someones written code https://github.com/rene-win/esp_avr_programmer that I'm going to be ripping off for that.
I'm using a Wemos D1 mini, even though it's supposed to be 3.3v hooking the RX and TX pins up directly seems to work.
Contributions will be greatly appreciated.
EDIT
It's a bit rough round the edges, but you can now upload a hex file to flash the attached atmega.
VW Beetle 2003
Outlander charger
Chademo Charging
celeron55
Post by celeron55 »
So you directly connect (taking care of different pinout) the Wemos D1 mini to GND, 5V, RX, TX and RST in the "FTDI 5V" connector and it just works?
pretty much, yea. I'd read https://hackaday.com/2016/07/28/ask-hac ... -tolerant/ and though what the hell, I'll give it a go.
I've flashed a hex with the web interface that prints a serial message and this started appearing in the output. So on to cleaning up the code.
VW Beetle 2003
Outlander charger
Chademo Charging
Web Interface now supports
-Updating the Atmega Firmware
-Sending Commands
-Viewing Output Log
I'll have to look at some changes to the charger code next, moving the configuration parameters in to EEPROM and allowing this to be set from the Web Interface.
VW Beetle 2003
Outlander charger
Chademo Charging
Fantastic!
Leo M
Post by Leo M »
Ждём продолжения ! Очень интересно.
I'm starting to try charging again with my new inverter but I'm having issues with the current sensor calibration.
Not accepting current calibration values: 503, 1023 (out of range)
How have you selected the values in
	if(il1_1 < 460 || il1_1 > 570 || il2_1 < 460 || il2_1 > 570){
VW Beetle 2003
Outlander charger
Chademo Charging
celeron55
Post by celeron55 »
They're just values in the middle of the range around 2.5V. 1023 sounds like something isn't connected right, as it's the maximum value the ADC can read and would mean hundreds of amps. Good thing I bothered to add that check...
You're right there, I've probed the via for A5 and it's up at 5v. Can't see a reason why that would be, I'll have a poke around.
Unplugging the current sensor drops it to 0v. Same issue with my old current sensors too. Not sure what else to check
VW Beetle 2003
Outlander charger
Chademo Charging
