johu wrote: ↑Wed Aug 05, 2020 11:31 am
You should certainly see an INPUT to the array when fstat > 0 and amp > 0 e.g. by setting fslipspnt=1 and ampnom=1. Could it be that pwmpol is set to ActiveLow? If you can't see pwmpol type "flag pwmpol ~hidden" into the custom command field and refresh.
The Darlington output of course only creates a visible signal when connected to the power stage AND the power stage is enabled via MSDN. So it should be resting at around 15V and pulses pull down to GND.
Thank you for your feedback Johu.
I've got it turning (on 2 phases), and then measure the signals from the Darlington array (in & output) 2 are active going down, while MWU stays flat on the input from the darlington compared to the other 2. Correct, Darlington output signal for MWU is always 15V, where the other 2 switching to GND.
PWMPOL is on ACTHIGH, MSDN on 12v, while running Fstat 5Hz and amp 37813(AMPnom 100%).
any other thoughts, or scenario's I can check?
