Toyota MGR Rear Traction Transaxle
Re: Toyota MGR Rear Traction Transaxle
dear Bexander.
I've been following your work for a long time.
and I appreciate your work.
could you please help me and answer some questions.
1. according to your photo of the installation between the inverter and the motor, I can not see the order of connection of three-phase wires, I need to see the order of connection. on the inverter, the numbers for the current sensor and the numbering of the phases I marked correctly. and correctly marked on the engine?
2. I have problems with setting parameters. can i see your parameters? and which version of the firmware did you choose V4.96 ---- V5.06.
3. how is syncofs and syncadv configured? for some reason I did not find syncadv on the new version.
viewtopic.php?p=29505#p29505
- bexander
- Has thanked: 63 times
- Been thanked: 89 times
1. With the phase order markings on the motor, on the inverter I have the opposite order i.e. switch 1 & 3. Phase order as in picture above. I don't know the order of the current sensors but it is the stock Toyota placement and then using the logic board to handle the connections.
2. My latest parameters. 5.06 is the SW I would recommend at this stage but to tune syncofs you might need to switch to 4.94 temporarily to get manualid/iq to work correctly.
3. Syncofs is tuned as described in this video: https://www.youtube.com/watch?v=1SlL6cEoRBg
Syncadv is not normally tuned.
Thank you so much. I'll try. I was wrong. not syncofs, but synsofs as configured
- bexander
Maybe my phase order is as described in the picture... I will have to double check when I get home.
- Has thanked: 157 times
- Been thanked: 1011 times
https://openinverter.org/wiki/Using_FOC_Software
Use 4.97.R software https://github.com/jsphuebner/stm32-sin ... ag/v4.97.R
With tuning done you can use a newer software.
syncofs know how to regulate
- bexander
That is not needed for resolvers. It is used for sin/cos ICs so you can configure medium voltage.
- bexander
Phase order double checked and the picture has the same order as I do.
Many thanks to everyone. I respect everyone. I will let you know the results soon
установил прошивку 4.97. R-foc
installed firmware 4.97 R-foc.
вроде бы отрегулировал syncofs по инструкции.
seems to have adjusted syncofs according to the instructions.
при включении старт и вперед с помощи акселератора, двигатель крутится вроде бы нормально.
when you turn on the start and forward with the help of the accelerator, the engine seems to be spinning normally
когда переключаю назад тоже нормально крутится, но при отпускание акселератора двигатель все равно крутится но медленно.
when I switch back, it also spins normally, but when the accelerator is released, the engine still spins but slowly.
регенерация не требуется.
no regeneration needed.
где я ошибаюсь
where am i wrong?
- bexander
My best guess is to try adjust the syncofs value and see if it changes anything.
idle mode seems to be active (set to 3), which might explain this behavior.mikmur wrote: ↑Fri Jul 09, 2021 8:35 am установил прошивку 4.97. R-foc
где я ошибаюсь
where am i wrong?
params G 09072021.json
installed firmware 4.97. r-foc. until I get it syncofs, I will not change the firmware.
in the same digits syncofs behaves strangely. when entered into manualid 20 amps or more amperes 90 ..... .....the engine spins back and forth. when entering manualid 0 amps and enter ...... the motor will spin up quickly and stop.
what's wrong again, puzzling
- bexander
Maybe the resolver phases are switched?
If you slowly turn the motor by hand, what does your angle plot look like?
Idle mode is set to always on, I do not think that will cause your issue, but try setting it to off.
Also, you have "dirmode" = Switch just as I do, this needs to be tied to 12v for the syncofs tuning process to work.
Edit: I think your syncofs value is on the "wrong side" of the valley, when you use the throttle it appears the MGR rotates in the opposite direction selected.
Hello everybody.
после долгих мучений мотор вроде нормально раскрутился.
after long torment, the engine seemed to spin normally.
для установки sincosofs необходимо измерить напряжение с энкодера (после резистивного делителя)
to install the sincosofs, you need to measure the voltage from the encoder (after the resistive divider)
чтобы раскрутить мотор-редуктор медленно, руками, один оборот трудно.
to unwind the geared motor slowly, by hand, one revolution is difficult.
как-то раскрутил и замерил напряжение между GND и с энкодера (после резистивного делителя).
somehow unwound and measured the voltage between GND and from the encoder (after the resistive divider).
от минимум бил 0 вольт, до максимума 0,65 вольт.
from a minimum beat 0 volts, to a maximum of 0.65 volts.
according to instructions (((U1+U2)/2)/3.3)X4096
U1=0.00V
U2=0.65V
Sincosofs=806.78
вот видео и если что не так с параметрами жду комментариев
here is a video and if something is wrong with the parameters I am waiting for comments
обновление:
renewal:
напряжение поднял до 270 вольт
voltage raised to 270 volts
переснял видео заново
reshoot the video
добавил графики разные
added different graphics
U1=0.00V
U2=0.65V
Sincosofs=806.78
обновление:
renewal:
reshoot the video
- Bratitude
- Has thanked: 57 times
- Been thanked: 170 times
hey folks, wiki page made here. please help fill it up with relevant info:
https://openinverter.org/wiki/Toyota/Le ... axle_Motor
- Has thanked: 243 times
- Been thanked: 59 times
I've come across a very cheap one of these and I was wondering how easy it might be to modify the body to remove the diff. Has anyone opened one of these up? Looking at the pics it's difficult to tell but I'd be interested to know if it's possible to separate the motor from the diff and make it much smaller.
- Has thanked: 138 times
- Been thanked: 65 times
Had an Estima one appart some time ago, and locked the differential, as wanted a single wheel output , and used it to push a 1999 prius .
Housings came appart fairly easily, and didn't cut the case .More recently, last year passed it on to another enthusiast, who cut away the casing, to utilize just the motor part, as a generator..
I can find more details from him if that helps.
I checked with my friend, At this stage, the MGR , housing has not been cut down.
Will update you when any relevant pictures are taken, is not sounding imminent.
When cut down, I guess it would be a comparable size and Kw to the I 3 Rex,
One complication is that the MGR I think drips or mists oil around the windings, to take heat to the outside case, and the oil is lifted to a channel by reduction gear rotation then distributed by spray from the rotor.. I could be corrected on this, was many years have passed.
Is your intention to use this as a generator?
