BMW hybrid battery group buy
Re: BMW hybrid battery group buy
I would also be interested in 24 modules if this is still happening?
To the UK
Dan
To the UK
Dan
Am also interested in joining this group buy. I am UK based.
My project design is not decided yet as am signed up for the course in Ireland in the Autumn but happy to commit now for at least 24 modules.
Hi Jaanus, thank you for your engagement!
I am interested in 60 modules.
And can pick them up in Germany if possible.
Hi, new here on the forum.
If its still open i would like to commit to 12 modules.
(Im located in Denmark)
- Been thanked: 8 times
It’s going to be a long time before I can use them, but I could commit to 24 modules if this is still on.
- jnsaff
- Has thanked: 2 times
Seems like there is some progress and the commitments should be in by the end of this week. If there are any peeps who want to join, please do so now and any current committers please think about your needs and whether they have changed. If all who are committed also please send me your e-mail addresses via PM so I can take further communication off the forum and make things happen faster.
Thank you all for you patience and engagement!
I am interested in 18 modules. Unfortunately somehow I can't send you a PM.
Netherlands
Netherlands
- Has thanked: 157 times
- Been thanked: 1010 times
Now you can, you need one approved post before becoming a real member (spambot counter measure)
- SciroccoEV
- Been thanked: 15 times
as it goes to an end, I'm interested in 24 modules / 36kWh.
NW Germany.
NW Germany.
Was it established whether they are going to be the old or new generation? It looks like if they are the old ones the energy density is way less than any of the other modules out there, which would make it a non starter for me.
Just out of interest has anyone gauged the power density?
How many Amps can these Gen3 or Gen4 packs provide pulsed?
34Amp hours Capacity. So safe C rate?
The main fuse seems to be 200amps so that’s around 6c.
I read earlier in the thread that Damien was interested for Lexus/Toyota inverter application? Doesn’t that inverter want 450+amps from the battery sometimes? Would that be ok if you ran 2 packs in parallel (custom fuse and Contactors and buss bars to handle the current)
- jnsaff
As full voltage pack is about 9kWh you’d most likely want to parallel 2-3-4-5 or so packs. So this should be no problem at all.
Hi all,
Just new here and going to be a while before I can use them but I can commit to 12 modules/18KW.
Ireland
Ireland
- Has thanked: 75 times
- Been thanked: 303 times
Is this likely to come to fruition before we in the UK kick ourselves where it hurts repeatedly and then have completely no idea on imports and tariffs? 1st of Jan 2021
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
- SciroccoEV
I'll double my commitment to 12 modules. It's looking like I may have a new project.
I previously put myself down for 12 modules, but am now up to 36, or maybe 48 modules.
If any of the Aussies are interested in shipping together, I have and an indicative freight cost to Sydney, and happy share that.
We would need an MSDS I'm guessing that must be available?
Michael
Michael
- rstevens81
- Has thanked: 23 times
- Been thanked: 92 times
I would not worry, there will be so much political pressure on Bo-Jo (The clown?), not to SMEG that up, as businesses need to cary on trading post "The Event", I expect VAT [+2.0% or 2.7% see below] & will most likely be payable, but hey still cheap as £60/kwh. (plus shipping of course)
Current 2021 Guidance
https://www.gov.uk/guidance/declaring-g ... nuary-2021If you’re importing standard goods into Great Britain from the EU between 1 January and 30 June 2021, you:
can use ‘entry in the declarant’s records’ without getting authorisation in advance
do not need to make an entry summary declaration
Edit:
Just found it .... https://www.check-future-uk-trade-tarif ... y&n=25&p=1
8507600018
Lithium-ion polymer accumulator equipped with a battery management system and can-bus interface with: -a length of not more than 1600 mm, -a width of not more than 448 mm, -a height of not more than 395 mm, -a weight of 125 kg or more but not more than 135 kg, -a nominal voltage of 280 V or more but not more than 400 V, -a nominal capacity of 9,7 Ah or more but not more than 10,35 Ah, -a charging voltage of 110 V or more but not more than 230 V, and -containing 6 modules with 90 cells or more but not more than 96 cells enclosed in a steel casing for use in the manufacture of vehicle capable of being charged by plugging to external source of electric power of heading 8703
UK Global Tariff 2.7%
Notes: UK Global Tariff rate: 2.0% An Autonomous Suspension applies, this will be reviewed in due course
- mackoffgrid
- Has thanked: 4 times
Hi Michael, I'm up for 36 (+) and I'm in Brisbane. I'd be interested in what you have. I wonder about collecting enough orders to make a full container and have it shipped from the wholesaler rather than double shipping. Is the wholesaler in the US ? ( i have prices for shipping from there).michaelh wrote: ↑Fri Aug 07, 2020 4:38 am I previously put myself down for 12 modules, but am now up to 36, or maybe 48 modules.
Michael
Cheers
Andrew
https://github.com/mackelec/SolarUte
meFDCAN Arduino Library 3 FDCAN port stm32G4xx
meCAN Arduino Library 2023 version 2/3 CAN port stm32F0xx, stm32F1xx, stm32F4xx, stm32L4xx
- Has thanked: 282 times
- Been thanked: 65 times
I'd like to jump in for 12 modules. First post so will PM email address when I get passed!
Are the modules only available in multiples of 6? I'm not building an energy store or EV conversion, I'd just like one module for various experiments and maybe to build a lawnmower
Thanks.
Thanks.
