FS: Nissan Leaf 24 kWh pack (87%) with lots of hardware
Been thanked: 959 times
I am selling my trusty 24 kWh Nissan Leaf pack that I replaced by a 40 kWh one.
I bought it second hand from New Electric with less than 50.000 km and 90% SoH. Meanwhile the BMS displays 87% SoH.
It was always run under surveillance of the Nissans BMS, never been overcharged or deep discharged. I have covered about 20.000 km with it and done around 100 quick charge sessions with 50 kW.
One of the cells has a slightly damaged pole which happened when unbolting the positive battery cable. It is electrically still functional though and doesn't affect the cell itself.
Included is
  • 48 battery modules
  • LBC (Nissan BMS)
  • LBC wiring loom both HV and LV
  • M6 rods for stacking 24 modules
  • Pole covers for 24 modules with embedded wiring loom and busbars
  • Adapter cable for changing cell order (probably not needed)
  • Relay assembly (welded)
  • Heater relay (not on picture)
  • Original fuse with holder but without disconnect jumper
  • Cover plates
  • Bolts and bus bars
2500€, self pickup in Kassel, Germany
Re: FS: Nissan Leaf 24 kWh pack (87%) with lots of hardware
Still up
