Hoping to find a new home for some quality used / new parts. Make an offer if you see something you can use!
Photos: https://photos.google.com/share/AF1QipP ... ZNZjFkbmpB
- Adaptto Mini complete system with BMS & Charge Cable New $425
- Delta-Q 912-9600 x 3 units show wear but fully functional, used $325 each
- Manzanita Micro MK3x8 BMS Boards Qty 12 with connectors and Ethernet interface $1300 (New was over $4K)
- Kelly Controller KDH12801B 800A 24-120V Used $500
- Texas Instruments EM1401 BMS 6-14 cell dev board with pigtails used $125
- Remy / Borgwarner HVH250-90 Cores - Make Offer
----1 X Rotor Only
----1 x Cartridge Motor, diassembled, serial wound
----1 x Bare rotor & stator, parallel wound
