Skoda Superb 1 (VW Passat B5.5) hybrid DIY
mrkvo
Post by mrkvo »
Hello,
I would like to show you my hybrid conversion of VW Passat 1.9TDI B5.5.
180S2P A123 LiFePo4, Siemens S210 400V inverter.
Guys, would like to ask you how to pass it thru TUV in Germany.
All components I am using have its EMC tests, etc.
Any possible info, who should I contact, what to say, how is the cert. process going would be welcome!
EV_Builder
Has thanked: 16 times
Been thanked: 33 times
Re: Skoda Superb 1 (VW Passat B5.5) hybrid DIY
Post by EV_Builder »
How much kw is that servo?
Ps. is that a mining rig in the background :)
muehlpower
Has thanked: 12 times
Been thanked: 102 times
Post by muehlpower »
The leaflet MB_FZMO_764 is decisive for the conversion. You can buy it from tüv. I got it.
mrkvo
Post by mrkvo »
Hello,
many thanks for the first info ever I have about the certification!
It helps me to kick-off.
So, I will have it with respect with this norm (I was respecting some EHK norm about this during building).
What to do then?
BTW Yeah its mining rig.
The servo has 44Nm * 3.8 (differential gear ratio), 3.5kW I am not sure how much exactly.
It is impossible to run on it only, but as a hybrid it is amazing.
mrkvo
Post by mrkvo »
A quick question. TUV estimated approoval process cost is > 10 000Eur - is it real?! Or they simply does not want to do it, so they try to overestimate the cost?
Has thanked: 157 times
Been thanked: 1005 times
mrkvo wrote: Mon Nov 22, 2021 3:05 pm A quick question. TUV estimated approoval process cost is > 10 000Eur - is it real?! Or they simply does not want to do it, so they try to overestimate the cost?
Yes, that's what clueless tüv engineers do, unfortunately. I payed 500€. Here is more info: https://openinverter.org/wiki/Germany
EDIT: it was 600€ viewtopic.php?p=10749#p10749
