1993 FD Rx7 with Tesla LDU and ElectricGT Batteries
rjmcdermott81
Re: 1993 FD Rx7 with Tesla LDU and ElectricGT Batteries
Post by rjmcdermott81 »
More progress on the exterior of the battery box.
mdrobnak
Post by mdrobnak »
Awesome work. I can't wait to see how this turns out.
I did some math and I think the Energy modules will be fine for my long-term use. But I think you're gonna have lots of fun with your setup!
-Matt
rjmcdermott81
Long while since my last post but progress has been steady.
Obligatory first test drive!
Make note that somewhere between bench testing and wiring the car... R/D got switched and I nearly took out my tool chests.
alexbeatle
Has thanked: 40 times
Been thanked: 13 times
Re: 1993 FD Rx7
Post by alexbeatle »
Boxster EV wrote: Tue Dec 22, 2020 9:00 am Yes, buy the 23 pin connector from DIY autotune. It makes the wiring a breeze and takes out the element of doubt regarding bad connections at the plug (this plug take A LOT of abuse from the weather and road debris). You will however have to de-pin the encoder wires from the 23 pin and replace them with shielded cable.
https://www.diyautotune.com/product/ms3 ... r-harness/
Does it work on the SDU as well?
