Tesla Model 3 Battery Build
- dougyip
- Has thanked: 5 times
- Been thanked: 7 times
Re: Tesla Model 3 Battery Build
Kia Soul EV Forum. The data is available via OBDII extended format. I have also gotten the onboard 6.6kW charger to work by broadcasting recorded CAN communications from a working vehicle. When you are ready, PM me and I can send over files.
Very cool. I am using a model 3 pack in my conversion... my box design is completely different, I will have to do a writeup when I am done. I am in a cold climate, so I decided to use a high strength fire retardant structural foam to provide most of the structural connection and double as insulation, with mechanical front/rear/top/bottom clamps on the ends and center.
Can you share more details about how you drilled the busbars? I accidentally de-laminated one of mine while experimenting with trying to bend it while I still thought it was a solid bar, and now I am working on an alternative solution. Are you sure they are laminated aluminum, the other busbars Tesla uses in the pack are laminated copper with some kind of silver surface finish.
- dougyip
We actually just cut off the ends of the busbars with a cut-off wheel on a dremel tool, then re-used existing holes to attach our own connecting bus bars made from Eriflex flat bus bar material. I don't remember seeing any copper colored material at the cut ends.
Very possible they used different materials for the module busbars, I was just curious. Any chance you have or can take closeup photos of the bolted connections using the existing holes? that was exactly my thought to begin with, but after cracking the laminations on my first attempt at bending it, I was hesitant to bend them up far enough to get a nut underneath.dougyip wrote: ↑Tue Jul 28, 2020 7:17 am We actually just cut off the ends of the busbars with a cut-off wheel on a dremel tool, then re-used existing holes to attach our own connecting bus bars made from Eriflex flat bus bar material. I don't remember seeing any copper colored material at the cut ends.
- dougyip
If you look at the 2nd photo, you can see one of my connections between two modules. . The 3rd photo shows two studs pre-installed ready for the external Eriflex connection to the HV fuse. I'm using existing holes. To decrease the amount I had to deform the bus bars, I made "backing nuts" out of 1x1x3/16" copper with 1/4 - 28 threads for studs. By using studs, you do not have to get a wrench underneath to back up the nut.
Good idea about fabricating a thin plate and threading in a stud. I'm going to try and replicate the technique.
Really interested in learning more about this. Insulating, fire retardant foam sounds like a winner.Ken_S wrote: ↑Tue Jul 28, 2020 5:12 am Very cool. I am using a model 3 pack in my conversion... my box design is completely different, I will have to do a writeup when I am done. I am in a cold climate, so I decided to use a high strength fire retardant structural foam to provide most of the structural connection and double as insulation, with mechanical front/rear/top/bottom clamps on the ends and center.
Hi!
Does the Orion BMS work well when you connect it like you did? I'm thinking of temperature sensors and so forth.
I have a model 3 battery pack on the way and I'm thinking of either go with the Orion BMS or wait for the open source board to be available. Both options have their pros and cons.
/Johannes
/Johannes
Ken, Did you ever finish this project? Did you finalize the development of your crimp type edge connection PCB for the interface between the Telsa Flex PCB Model 3 module to the 3rd Party BMS?Ken_S wrote: ↑Tue Jul 28, 2020 5:12 am Very cool. I am using a model 3 pack in my conversion... my box design is completely different, I will have to do a writeup when I am done. I am in a cold climate, so I decided to use a high strength fire retardant structural foam to provide most of the structural connection and double as insulation, with mechanical front/rear/top/bottom clamps on the ends and center.
I somehow missed the notification on this.
The system isn't fully assembled yet (embarrassed to say, but life got in the way of progress ) However I have connected the Orion Cell taps to the battery modules. The connector I am using is: https://www.digikey.com/en/products/det ... LF/1002508 They crimped easily, I reinforced them with hot glue to provide some strain relief.
