Tesla Model 3 Battery Hacking
- Has thanked: 97 times
- Been thanked: 204 times
Re: Tesla Model 3 Battery Hacking
Very well documented Damien, hats off. I gave up when the LTC6820 solution turned out to be a none starter, did not dig into why.
If they literally increased all the pulses by a factor of 2 I wonder if any of the SPI data still holds true. But then again reverse engineering it will still be possible.
- Kevin Sharpe
- Been thanked: 4 times
OK, thanks for the clarification
- Kevin Sharpe
Tesla BMS connector cell count
- Been thanked: 87 times
Got my little analog front end boards in from JLC. To my amazement they work:) We can now translate Musk-spi into 3.3v pulses ready to feed into an fpga or micro for decoding into data.
I now have a PACK 25S battery pack. Can I remove the original control board in the middle? Then connect a 25S third-party BMS to make it work?
Thank God! thank you!
- Kevin Sharpe
You can do anything you want but whether it's a good idea is for you to decide
If you want to discuss this further please start another thread so that we can focus on Model 3 battery hacking here.
- Been thanked: 960 times
Am I late to the party?
Thought I'd post some ltspice goodness.
This should recover a true SPI data stream with clock, data and CS that can be processed by a standard SPI peripheral.
Delayed clock and removed OR gate
- isospi.asc.zip
- (1.03 KiB) Downloaded 67 times
Thanks Johannes. Building this will be fun:)
Connector used on the board for the isospi is Molex Mini50 Series, 34912 Series Number, 1 Row 2 Way Surface Mount Plug PCB Header.
Black for BMB-A (batman)
Part number : 34912-8020
RS Stock No. 131-4729
Grey for BMB-B (robin)
Part number : 34912-8021
Mouser No: 538-34912-8021
New design transciever board in production at JLC. Based on a Xilinx Spartan 6 FPGA running at 100MHz. Ultimately will provide receive and transmit with spi and uart interfaces. Couple this up to Simpbms and we should be good to go:)
....ok I was going to put a vga port on it but I stopped myself
Does this mean I can buy this product within a month?Jack Bauer wrote: ↑Mon Apr 20, 2020 5:26 pm New design transciever board in production at JLC. Based on a Xilinx Spartan 6 FPGA running at 100MHz. Ultimately will provide receive and transmit with spi and uart interfaces. Couple this up to Simpbms and we should be good to go:)
Well done JB / DM! Connects to the 2-wire connection from the module boards?
Yeah will plug into the existing harness. Of course it probably won't work so don't get too excited just yet:)
- Kevin Sharpe
This is fabulousJack Bauer wrote: ↑Mon Apr 20, 2020 5:26 pm New design transciever board in production at JLC. Based on a Xilinx Spartan 6 FPGA running at 100MHz. Ultimately will provide receive and transmit with spi and uart interfaces.
Can I suggest that you keep the FPGA design closed source and sell the PCB as a tested and supported product? We really do want to wave you off to Lanzarote one day
- muehlpower
- Has thanked: 12 times
- Been thanked: 96 times
Do you think i can rearrange the module as shown. The order of the boards remains, but the HV part is different. The reason for this is that I want to stack the short modules on top of the Long ones so that they fit between the frame rails.
- Kevin Sharpe
We're not currently aware of any limitations that would prevent you from doing that
Nice, any way of grabbing SPI data logs? So we can start looking at doing some decoding.
These simulated or done on actual hardware?
Thats a simulation on Xilinx ISE. Hope to start actual hardware tests next week. Once proven any data logger like a Saleae or Analog discovery can connect to the spi or uart ports on the board and grab data. Initial release will be receive only. If it works out on the bench I'll pop one in the post to you Tom.
First tests with the Spartan 6 FPGA. Looks like we can detect the long pulses in order to decode CS. Now onto clk and data.
Good news is our new pcbs with the Xilinx FPGA onboard work a treat.
Do your boards work with each battery module board, or require the main Model3 BMS?
