LDU inverter gate drive PCB fault finding [SOLVED]
- Boxster EV
- Has thanked: 35 times
- Been thanked: 26 times
I’m playing with one of these on the bench out of a spare inverter. Does anyone have any specs or guidance on fault finding them?
Re: LDU inverter gate drive PCB fault finding
Hello
When I repaired the three pcbs, i digged deep In the manual to the igbt controller pdf.
https://www.mouser.se/ProductDetail/726-1ED020I12FA2XUM
I traced down fault at the igbt and transistors/mosfets.
And resistors/diodes between igbt controller and transistors/mosfet.
A litte error will be fatal because that you have 400vdc in to that little pcb.
- Boxster EV
Thanks, the spec sheet is helpful. I’ll start playing.
Not sure I’ve got the cajonas to desolder the whole PCB and replace everything en masse like you did.
- Boxster EV
Your’re not wrong - IGBT driver is fried. The part is currently out of stock.
- Boxster EV
I don’t know why this IGBT driver fried itself, but I managed to repair the board by transferring a second-hand semiconductor over from a parts bin inverter section courtesy of Damien – in fact this is the second LDU that’s been successfully repaired using these scrap parts.
Very important that the lacquer type material that covers the component needs to be removed by warming it up before de-soldering - used a hot air solder station for the removal process and was very careful not to damage the PCB with too much heat.
Upon powering up the inverter, the red fault LED is no longer illuminated and the inverter now goes into run mode without an overcurrent error.
- Boxster EV
Re: LDU inverter gate drive PCB fault finding [SOLVED]
Made a quick beginner’s guide video whilst doing a bench test.
Nice save!
- Boxster EV
