idclim
- This parameter is mainly relevant for CAN operation. It is transmitted via CAN to let the vehicle know how much DC current the charger can deliver.
(Each charger module maxes out at about 15.5A so the maximum total charging current is 46.5A. Since the total power is also limited to 10 kW it depends on the output voltage as well. There is no need to be exact on this, the firmware will automatically limit the AC input current to each module to the hardware maximum.)
idcspnt Direct Current Setpoint? What's a setpoint?
- DC charge current limit.
- An additional limit to charge power.
- It is also mapped to the CAN bus so if you have a BMS that calculates a maximum charge current you can forward this to the charger.
