Openinverter SDU board, contactors, and inductance  [SOLVED]
catphish
Has thanked: 94 times
Been thanked: 179 times
Post by catphish »
Sorry if this is a FAQ. When using the open source SDU board, is it necessary to place flyback diodes across the contactors, or does the board completely protect against the contactor coil inductance? Obviously adding the diodes is easy enough, but I wanted to confirm whether this was necessary.
Has thanked: 157 times
Been thanked: 1005 times
Re: Openinverter SDU board, contactors, and inductance  [SOLVED]
It varies. Some boards have specialized drivers with overvoltage protection (BTS133) but some don't if these weren't in stock. Just use a diode to be sure. Or check the printing on the drivers.
