Tesla sdu inverter relocation??
thetdiguy
Post by thetdiguy »
I picked up a sdu i was wondering can the inverter be Relocated?
Obviously cover plates need to be made what size wire would be sufficient?
EV_Builder
Has thanked: 16 times
Been thanked: 33 times
Re: Tesla sdu inverter relocation??
Post by EV_Builder »
thetdiguy wrote: Tue Oct 12, 2021 11:37 am I picked up a sdu i was wondering can the inverter be Relocated?
I have the same question / situation. I used/plan to use 70mm2.
The acces holes to the motor poles now have a cover plate with 3 EMC clamps.
The encoder and thermistor I used 7x0.5mm2 wire.
I made alloy cover for the inverter and a cover for the engine.
I will post some pictures in my build thread when I mount it.
(Panamera build)
qmedia2651
Post by qmedia2651 »
Yes I'm doing it for my 1991 300ce mercedes-benz conversion project. Only have 18.5 in to install sdu rear.
See pics
qmedia2651
Update
Inverter 1 inch off set Spacer STL files
STL_Inverter_Shims.zip
(58.53 KiB) Downloaded 35 times
qmedia2651
PCB design to connect the Encoder from the motor.
js1tr3
Post by js1tr3 »
Mind sharing the cad for the endplate. After destroying two sdu inverters with my v4 board I might try with a less expensive volt inverter.
1988 Porsche 911 targa with warp11 motor. Soon to be Tesla SDU.
qmedia2651
Inverter HV Cover.stl
(528.11 KiB) Downloaded 61 times
Inverter for SDU HV Cover STL file
qmedia2651
Tesla inverter relocation inverter HV and Encoder new cable routes.
All done on 3D printer.
qmedia2651
I did the cover plates with a roter bit.over the inverter edge
Pcb encoder connection at motor cover
